Go to Post Chief Delphi isn't for making enemies...it's for making friends. - Alex Pelan [more]
Unread 18-02-2014, 10:41
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
Rookie Year: 2011
William Kunkel is an unknown quantity at this point
Limitations on actions in disabled mode
What are the specific limitations on code when the robot is in disabled mode? I assume (though I don't know for sure), that the robot can't, for instance, run motors while it is disabled, but what are the limitations? Can relay values or solenoids be set? And how is this enforced?
Unread 18-02-2014, 10:47
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Limitations on actions in disabled mode
Relays and Solenoids can be set, but they won't actuate until the robot is enabled. You can also send and receive values from the dashboard while disabled. You can read values from sensors as well.
Unread 18-02-2014, 10:49
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Nothing can be operated while disabled - relays can't be switched, motor controllers can't be driven, solenoids can't be fired. The intent of disabled is DISABLED - the robot can't "do" anything.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 18-02-2014, 10:50
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I don't recall if digital outputs are set during disabled mode and I'm not going to be near the robot for several hours.
Can anyone clarify?
Unread 18-02-2014, 11:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
There's no limitation on what you can program, but any motors or servos or relays or solenoids you try to actuate on the robot will have no effect when it's disabled.
This is enforced by the FPGA on the cRIO. You have no ability to override it.
The Digital Outputs on the Digital Sidecar do still work when the robot is disabled, so you can control custom circuits. Custom circuits are not permitted to control any robot actuators, so again nothing you do with the program while the robot is disabled will make anything move.
Unread 18-02-2014, 12:22
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
Digital and Analog Inputs are active. We leave the robot disabled and read sensors in the LabVIEW periodic tasks. We have used this to verify operation without having to drive the robot. The Analog inputs are used for the Gyro and Potentiometers. The Digital inputs are used to verify the operation of the Sonic Sensor, input switches and Encoders.
Unread 18-02-2014, 13:00
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Sensor inputs through DIO, Analog, I2C, Serial, SPI, Ethernet, for example camera tracking will be operational during Disabled, so decisions can be made in the code that can be acted on immediately when the FPGA enables PWM, Relay, Solenoid outputs during Autonomous or Teleop.
