Re: 2601 Three Ball Auton Teaser
but check out that kid at the end doe
much excite. #ejshuffle |
Our pneumatics expert (the guy filming) ran around the gym screaming for a solid 15 seconds after this test.
But besides that, awesome job on doing a 3 ball auto, my only question is how repeatable is it? |
Very impressive. Any plan for the third ball rolling left/right instead of straight forward?
Why is that?
G5: Quote:
This is awesome!
My question, how consistently can you line up those three balls to push in the right direction/roll to the desired locations? From my experience with the practice scrimmages this weekend, getting balls to settle in the perfect spot is hard, plus each ball is unique in inflation and shape. Seems like this approach is highly dynamic. Are you using any feedback to make ball acquisition more consistent? Regardless, very impressive and unique approach to the three ball auto problem, well done! -Mike |
I can't wait for competition this year for many reasons... two of which are:
1.) 3 ball autos (or any multi-ball) 2.) The one goalie bot that blocks all three of them with PVC and sends an entire alliance running ![]() |
[quote=EricLeifermann;1345403]If a team starts in the goalie zone their ball can be placed in the white zone wherever the alliance see's fit.
I already knew that, hence why I asked "...if the robot starts in the white zone..." Quote:
#11
Q. [G5] At the start of Autonomous, 'bots in the white zone "may" be in contact with a ball. Does that mean that there is an option not to? If so, may the ball be placed elsewhere in the white zone? Or is it removed from the field? (Not clear from the rules.)
A. G5 requires that BALLS preloaded be touching the ROBOT. The "may" allows TEAMS to decide that they do not want to preload a BALL, in which case the BALL is removed from the FIELD. The only exception is for BALLS associated with ROBOTS that are not present for the MATCH or begin the MATCH in the GOALIE ZONE. This actually seems to be pretty clear. You cant have a "free" ball in the white zone. It either has to be touching another robot or off the field. |
#12
Very impressive. Looks like 2601 is going to make a big splash this year, you guys just keep getting better and better.
I worry about getting those balls to line up consistently, but I see no reason why that robot can't easily run a consistent 2 ball auto regardless. |
#14
On consistency: here's trial two (with Alex's reaction). http://youtu.be/qDpe8SGPlYg |
