Go to Post We are here to both learn and teach. - Steve W [more]
Unread 18-02-2014, 15:28
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Rookie Year: 2010
Team3763 Adam can only hope to improve
How to program the D-Link for wireless?
I've ran through, to the letter, the steps to program the D-link for wireless use available under the LabVIEW tutorials. The only problem is it's not working. I was hoping to get a more specific step by step on how to do it, as the one through the tutorials is out-of-date compared to the more recent D-link program.
Unread 18-02-2014, 15:39
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: How to program the D-Link for wireless?
Are you using the "FRC Bridge Configuration Utility"?
Unread 18-02-2014, 15:44
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
For use in your build space, set it to AP mode by using the switch on the back (2.4 or 5.0GHz, depending on what bands your laptop is capable of... if you don't know, go with 2.4 GHz first). Then plug in the laptop to the bridge, and launch the FRC Bridge Configuration Utility. Put in your team number and run it - it'll take care of the rest!
Then you just need to enable wifi on the laptop, join the new network that appeared (the name for the network should be your team number), and manually set your IP address to 10.XX.YY.05, where XXYY is your 4-digit team number. The .05 can also be changed to something else not in use, which lets you have your driver station and a programming laptop connected at the same time.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 18-02-2014, 16:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Chase the links from http://www.usfirst.org/roboticsprogr...ical-resources , focusing on Control System hardware and software, until you reach http://wpilib.screenstepslive.com/s/...o-for-home-use , then follow the directions.
Unread 18-02-2014, 16:32
Lead Programmer
Rookie Year: 2010
I tried using the FRC D-Link utility, but it said something about an error. I'm going to a meet soon so I'll be able to report back.
Unread 18-02-2014, 17:17
Just Itinerant
If the bridge is password locked or has an unexpected IP address, then you'll see an error message from the Utility and it will instruct you to use the reset on the back of the DLink to reset it to factory default settings.
Warning: only push the reset on the DLink AFTER it has already been powered up. Bad things happen if you are pushing the reset button as the power comes on.
Unread 18-02-2014, 18:10
Lead Programmer
Rookie Year: 2010
The error just says that an error occurred while initializing the computer network settings and that it must shut down.
Unread 18-02-2014, 18:35
Just Itinerant
Perhaps try the Utility from a different computer.
Unread 18-02-2014, 18:51
Lead Programmer
Rookie Year: 2010
No alternative computer with the software, sadly.
