Team UPDATE 2014-2-18
Posted on the FRC Manual site, 2/18/2014: http://frc-manual.usfirst.org/Updates/0#term 165
Re: Team UPDATE 2014-2-18
Best post-build re-definition I've ever seen. Ha.
Calling the new G40 seems very confusing to me. So now the human player must be much more cautious, because now if they got closer then 12 inches to the field its a tech? That seems pretty harsh, and that zone seems like it would be much harder to enforce then the field barrier, which is an easy thing to see if somebody crosses, verses the arbitrary safety zone, which is gonna be hard to keep a good eye on. Throwing a ball from the hp zone could easily cause your hands to cross it, but at a point 6+ feet off the ground, which would be hard to call.
I dunno. I think a human would be able to remain in the human zone, meaning 20" away from the field and 12" away from the safety zone, pretty easily. Just don't go over that railing. A human that is a few inches closer to the field doesn't have a real advantage, since they (humans) are so versatile.
Much better than the original rule which would very quickly have turned into the G22 of 2008 (which most off-seasons universally changed to not allowing you to reverse your robot fully THROUGH the plane of the LINEs, rather than BREAKING the PLANE, because G22 as it played at official events in 2008 was awful). |
I think this is a great rule change. By the letter of the law, yes, it seems that the human players now have to keep an eye on this Safety Zone instead of the field barrier. However, Overall I think it just allows the events to be called more consistently and easily by the ref crew. Meaning that the obvious calls (Robots with harvesters open extended well beyond the field) will be called and it gives the refs the freedom to not have to call every little infraction.
GDC has been awesome this year, can't wait to compete! |
