| Thread Tools |
Rating:
Display Modes |
Losing comm in Teleop
Hello all, after a few tests last night and perfecting our code in Debug mode, we have encountered a bit of a problem. Our robot runs perfectly during debug mode (wirelessly, might I add), but when we hard deploy the code and try to run the Driver Station we can't hold communication for more than half a second. We're only 5 hours away from bag n tag, so any help would be greatly appreciated!
Many thanks, |
Re: Losing comm in Teleop
Does this happen only in teleop? You may want to look at the Charts tab to see if that helps identify something. Also, is the cRIO rebooting? Is the DLink rebooting?
Greg McKaskle |
How are you doing the "hard deploy" of your code? You should be doing a Build followed by Run As Startup.
