Go to Post You know, if I was John V-Neun I would get a copyright on my name! - Jay H 237 [more]
Unread 18-02-2014, 19:31
tragic tragic is offline
Programming Mentor
FRC #4633 (Bobcats)
Rookie Year: 2013
tragic is an unknown quantity at this point
Exclamation Axis M1011 camera not working
So our Axis M1011 camera may have died today (I'm confident that this is the case but I could be wrong) I supplied 5.0V and 1.5A to the camera the green power indicator led would turn on then approximately 5s later it would shutoff.
I tried 2 different power distribution boards and also a work bench power supply.
Also tried having Ethernet cable from camera hooked up to my comp as well.
So my questions are:
1) Am I wrong in my diagnosis? This would to be great to know that this was a f*** up on my end and not the camera.
2) Is it possible to use camera's other than the Axis camera's.
3) I found some Axis M1011 Camera's on eBay would it be against the rules to purchase from somewhere other than AndyMark.(A $200 M1013 from AndyMark is not in the budget)
Unread 18-02-2014, 20:51
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Axis M1011 camera not working
Sounds dead if it won't stay on and you've tested the power feed wioth a multimeter to be sure.
You can purchase an Axis camera from any source.
But using a different camera could make for much more programming complexity, because it won't be plug and play. You may have to design your own support libraries.
Unread 20-02-2014, 18:49
Programming Mentor
FRC #4633 (Bobcats)
Rookie Year: 2013
Well I was hoping I screwed up but it is good to hear that there are no restrictions on where a camera is purchased. I'm going to try to get another M1011 for cheap but worse comes to worse I can learn how to code some libraries for a camera or find a compatible camera. Thank you for your assistance.
