Go to Post I have photos of students working the lathe dressed for a concert! Makes me wish for a formal dress night at robotics. - Mark McLeod [more]
Unread 18-02-2014, 21:05
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
Autonomuous seminoid help :)
Hi there. I am having problems with my program when it comes to the solenoids. When I run autonomous the drive motors and the window motor are running perfectly. Then my solenoids just flicker on and off within a fraction of a second when they should clearly turn on or off for at least a few seconds. I have double checked that there are no word errors in naming, which is hard to do with Global variables, to my knowledge the wiring is correct. Also, in tele-op everything works perfectly so it is definitely not a wiring or mechanical issue just programming. And advice will help. I will also attempt to post pictures below. Sorry for any obscurity.
ID:	16320  Click image for larger version
Unread 18-02-2014, 21:08
FRC #3179
Re: Autonomuous seminoid help :)
The first picture is the first half the second picture is the last half.
Unread 18-02-2014, 21:20
Your logic is very simple. I don't think the code you presented is to blame. I'd look to the code that is actually updating the motors and solenoids. Determine if it is possibly being updated from more than one place. Then check if the globals are being updated elsewhere.
Greg McKaskle
Unread 24-02-2014, 17:11
FRC #3179
Will do thank you!
