Go to Post Viva La FIRST Revolucion! - phrontist [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 00:48
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
coding, motors, spikes, help
Posted by bill whitley at 2/13/2001 5:00 PM EST
Student on team #70, Auto City Bandits, from Powers Catholic High School and Kettering University.
1) Can the Van Door motor be run from a toggle switch? It requries a speed controller, correct?
2) When wiring in the pneumatic pump, do we run direct 12V power to the compressor, and then connect spike to the solenoids? Where does the pressure switch come into play?
3) Can both the globe & window motors be run from toggle switches & spikes?
4) Is it possible for the trigger of joystick one and the trigger of joystick two to control the same motor? (IE, so left joystick rotates left, right joystick rotates right) Can you give (at least a hint/start) to the PBASIC code necessary to do this?
Bill
Team #70
"Who needs engineers when you have chiefdelphi.com?"
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Spikes with Motors GregTheGreat Electrical 22 11-11-2003 10:25
Can you use the spikes with the globe motors? Caleb Fulton Electrical 1 15-02-2003 20:13
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
