Go to Post All labor is donated by the webmaster "Brandon". - Mike Martus [more]
Unread 20-02-2014, 10:10
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
Rookie Year: 2000
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
Updated value in dashboard not getting to cRIO
I have found that if the dashboard updates a control using a local variable that the data is not sent to the cRIO and when the data is updated in the control by typing a new value in it does get updated. How do we programmatically update a control value and have it sent to the cRIO?
David Kolberg
2014- Mentor Iron Giants 5069
2004-2010 Coach SBotz Team 1327
2000-2003 Mentor Team 135
2016 St. Joe District Event Winner
2009 WFA Boilermaker
2008 Driving Tomorrow's Technology
2005 Innovation in Control
2005 IRI Spirit of Indiana
Unread 20-02-2014, 10:18
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Updated value in dashboard not getting to cRIO
How are you attempting to update a Control, which is output only, with an input from a local variable?
Perhaps a picture?
Unread 20-02-2014, 10:42
Mentor Iron Giants
AKA: David Kolberg
Rookie Year: 2000
Here is a picture, I am using the configuration file to load a value and place in the control using a local variable. I see the value get updated in the control but the new value does not seem to trigger a value change event to notify the network table to send a new value. I will try to use a property node to see if that works.
What I have is the ability to upload a set of parameters based on the driver hitting F2 or F3 to select long or short shooting. This updates a set of values that then I wanted to send to the cRIO in place of sending multiple sets and having the cRIO decide which set to use.
If I can not programmatically send data to the cRIO, then I will have to resort back to sending all the sets of data to the cRIO and then use buttons or something to tell the cRIO which set to use. Seems like this should be easily handled in the dashboard, but have not found any examples of programmatically sending a variable to the cRIO.
David Kolberg
Unread 20-02-2014, 11:04
Just Itinerant
A few ways to attach a picture.
- Use the Manage Attachments button when you create or edit a post (located lower down on the posting page)
- Use Attach as I see you just did
- web link to a publicly available image
- embed a weblinked photo
Code:
[ img]http://link[ /img]  (all without the spaces)
Here's an attached image passing array & cluster data from the Dashboard to the cRIO.
P.S.
For LabVIEW images it's best all around if you highlight the code and choose Edit -> Create snippet from vi
Unread 20-02-2014, 11:22
Mentor Iron Giants
AKA: David Kolberg
Rookie Year: 2000
Looks like using property value (signaling) works. It signals a value changed event after setting the value.
Thanks for your help.
David Kolberg
Unread 21-02-2014, 07:13
The binding was primarily intended for indicators coming from the robot and for interactive panel values. It was not really intended as a replacement for variable writes.
You are correct that value signaling will work. So will writing the value and writing the variable. If you have many variables, it may be useful to place them into an array or a cluster and flatten the cluster as Mark showed.
Greg McKaskle
