Go to Post Woodie once said he wanted to make our brains hurt. And I *don't* think he was talking about getting beaned by 198 grams of foam.... - Ken Patton [more]
Unread 20-02-2014, 14:07
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Joystick in Autonomous
Ignoring the fact that this is against the rules, if one were to program autonomous to take joystick input and the driver touched the joystick during autonomous, would the input be seen by the robot code? Or is that somehow locked out automatically?
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 20-02-2014, 14:17
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Joystick in Autonomous
Nope.
The code only sees the last values sent in the last packet before Autonomous started.
That packet info is ignored by the communications task during Autonomous.
Unread 20-02-2014, 14:21
Originally Posted by Mark McLeod View Post
Nope.
So it behaves differently than the Kinect, which is not ignored during Auto. Ok.
John Vriezen
Unread 20-02-2014, 14:31
Just Itinerant
Yes, the Kinect gets through because it was originally setup to be used to direct the robot during Autonomous.
Unread 20-02-2014, 14:42
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
But we have the code for the communications task, right? So if you wanted to, you could let the joystick value through.
Unread 20-02-2014, 16:17
Would modifying that code in that way be permitted? (even if touching the joystick is still illegal during Auto) I don't know if that is part of the code you are not supposed to touch.
John Vriezen
Unread 20-02-2014, 16:50
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You don't have the driver station code. I don't know enough about Windows DirectX programming to know whether you could read a joystick that is also being read by the drivers station and then send the data through an alternate communications method.
Unread 21-02-2014, 10:10
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
If joystick commands aren't sent during auto, is there a reason that the drivers have to stand back from the controls?
Unread 21-02-2014, 10:12
Just Itinerant
During Autonomous commands from the Driver Station can be sent other ways than the joysticks.
So keep back
Then there's that Kinect thingy...
Unread 21-02-2014, 10:26
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
@Mark, or anyone
If you set one of the axes before the match (say the "throttle" which doesn't have a centering spring), would autonomous be able to read that value?
Unread 21-02-2014, 10:28
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Originally Posted by Christopher149 View Post
@Mark, or anyone
Yes....I believe the defaults LabVIEW Auto Code already has the code needed to read it. But honestly, it's just easier to create a custom dashboard for setting certain boolean tasks for auto mode.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Rookie Year: 2010
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
I don't know, but I suspect there isn't code to prevent the joystick from being read. SmartDashBoard definitely is read and it seems unlikely they would introduce code to prevent other devices from being read.
You could try it as an experiment. There is a "practice" mode on the driver station that simulates a match of autonomous followed by regular. You could touch the joystick during the first 10 seconds of "practice" mode and see what happens.
If you do try it, post back here so we all know!
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
