Consistent robot flicker every 64 seconds
We noticed a really odd problem with the robot when we started doing full testing. Every 64 seconds, the robot "flickers" for a fraction of a second. Relays (and possibly PWMs) shift into neutral, as well as solenoid valves. There is an audible clicking from the solenoid valves and almost every light on the robot goes out. However, we don't lose communications, and everything is back to normal a split second later. Still, the behavior is very disconcerting, and we can't see any obvious explanation for it. Before I get into trying to flowchart the code to see if anything is illuminated, is anyone aware of any sort of loops in WPILib that run on a 64-second timer?
Re: Consistent robot flicker every 64 seconds
Does anything show up in the DS log when this happens?
Have you substituted a different computer as the Driver Station in case it's a Windows task popping up every 64 seconds (which I have seen before)? |
There's nothing on the DS. And we tried deploying just the simple robot template provided by Wind River, which removed the problem, so I think we can rule out the computer (probably).
We've had something similar happen, although it seems much less consistent (ie. could be 10 or 50 seconds). I've put it up to lag, although I've had a sneaking suspicion that it isn't. (how could it be even?)
I spent a considerable amount of time troubleshooting with a team at their build site where they were disconnecting over WiFi every 6 seconds, no matter what code was on the robot. Ended up being something with the driver station laptop and swapping it fixed the issue.
Can you post your driver station log file and a screenshot of it? It really is one of the most important pieces to tracking down issues. If you don't know how to get to it, go to the "Charts" tab on the driver station interface and then click the "Launch viewer" button in the bottom right. |
What language are you using?
Could be garbage collection. |
I think C++
Perhaps you have a memory leak that is causing the processor on the cRIO to reset every 64 seconds? That would explain why you don't loose communication but everything else resets and could be likely given C++ doesn't have a garbage collector.
You could at least easily test if this is the issue by downloading sample code onto the bot and waiting 64 seconds. Edit: I just noticed you said that sample code removes the problem, so I now highly suspect something in your code is periodically crashing. If its not a memory leak, you could try first uploading an empty file and slowly adding one class/file/functionality at a time to see which part is causing the crash. Last edited by k4mc : 20-02-2014 at 22:14. |
Do you happen to have a 16-bit unsigned int that is counting milliseconds?
#10
If the flicker is short, this isn't caused by a crash or reboot. I agree with Jared that something in the code is probably overflowing.
Greg McKaskle |
#11
I concur with the above. Go through your code and make sure that there are no overflow warnings (hopefully WindRiver alerts you to that).
#12
Check the NetConsole output. There could be helpful messages being printed there that could point you in the right direction.
