Go to Post Watch out world, FIRST is going to become mainstream! - Church [more]
Unread 02-20-2014, 08:52 PM
AdamWiwc AdamWiwc is offline
FRC #5185
AdamWiwc is an unknown quantity at this point
Speeding up and slowing down in autonomous
For some reason whenever I try to run this code; speed remains at 0 and it counts i up to x and then speed is suddenly changed to 1.0. Speed is supposed to be a decimal of x depending on how many times the for loop has run through. I don't understand why this is happening and would be very grateful for some clarity.
double speed;
int x = 200;
for(int i = 0; i <= x; i++){
double gyroAngle = gyro.getAngle();
speed = i/x;
chassis.drive(-speed,-gyroAngle * Kp);
System.out.println("Speed- " + speed);
System.out.println("Ticks- " + i);
Timer.delay(0.01);
Timer.delay(1.0);
for(int i = x; i >= 0; i--){
speed = i/x;
Timer.delay(0.01);
chassis.drive(0.0, 0.0); //full stop
Thanks
~Adam Wiwc
Unread 02-20-2014, 11:34 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
See http://stackoverflow.com/questions/3...oduce-a-double
Unread 02-20-2014, 11:51 PM
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
Rookie Year: 2012
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
Re: Speeding up and slowing down in autonomous
You're performing integer division. When you divide an int by a larger int, you get 0. Java gets rid of the decimal portion of the number. Try making i a double instead of an int.
