Go to Post Force yourself now, today, to learn one new thing each day. When you lay down on your fluffy pillow at night, before you say your prayers, ask yourself if you have learned anything new. If the answer is "NO" then you better get up and find something. - Al Skierkiewicz [more]
  #16   Spotlight this post!
Unread 26-02-2014, 20:21
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Best place to buy batteries and a charger?
Something of a puzzle to get the small gauge wire connected to the batteries without using the surface-disturbing clips that come with the charger. post or message me if you want instructions on how to hitch the big anderson connectors to the small charging cable. I put four of those chargers onto a cart a while ago.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #17   Spotlight this post!
Unread 03-03-2014, 11:15
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Don't hold out. Lots of people read this and would like to know how you do it.
The best way we've found is to buy some SB-50 shells with the proper sized contacts. APP makes some that easily solder to a 10-12-14 gauge wire.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
  #18   Spotlight this post!
Unread 03-03-2014, 14:06
FRC #2170
I put in a temporary hack to adapt the cables coming up on two years ago. It's working OK so I have little incentive to correct it. Look at original posting for short description and a couple of detail pics. More pics attached along with a shot of the mostly finished cart. This method has the advantage of allowing the battery side of the cables to be easily reused. There is electrical tape now covering the terminal adapter and ziptie. I really should find those Anderson replacement connectors and staple them to the cart in case I get enough energy to install them.
Name:	IMG_0626a cable adapt B4 ziptie.jpg
ID:	16471  Click image for larger version
Name:	IMG_0630a battery end of cable.jpg
ID:	16472  Click image for larger version
Name:	IMG_0769a battery cart front nearly complete.jpg
  #19   Spotlight this post!
Unread 03-03-2014, 15:25
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
That's how we do it too, though I always run out of connectors because we fix other teams chargers at events. I haven't bought any this year but I would have liked to have them with me when I was working at Alamo this weekend.
This is where I normally get mine.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
  #20   Spotlight this post!
Unread 03-03-2014, 22:34
Doc Wu's Avatar
AKA: Al Gritzmacher
Bill_B I actually like your way of doing it as well, because you are mounting the terminal block in your charging stand. I've seen so many teams with battery pigtails spliced onto the charger cord and taped up. It works, but it looks so ghetto!
  #21   Spotlight this post!
Unread 04-03-2014, 00:16
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
Team Role: Mechanical
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
We have had great luck with the andymark 3 battery charger. But their one charger we had that I warn against buying I dont remember what it is called but I will check on it Tomorrow.
