Go to Post FIRST doesnt care about the weather, and we still need a working robot. - Mike Heinowski [more]
Unread 21-02-2014, 22:08
w8jrt w8jrt is offline
FRC #4391
w8jrt is an unknown quantity at this point
Only one joystick works when two connected
We are trying to use two joysticks. they both show up on the drive station and if you activate anything on the joysticks the appropriate one will turn blue. In lab view we have usb1 associated with joystick 1 and usb 2 associated with joystick 2. no matter what we do only joystick one will work. if we reorder then on the driver station the control moves from one joystick to the other but only joystick 1 will work in labview. We've scoured he code looking for some inappropriate reference to joystick 2 that could be causing the error but we're stuck. Not sure what else to try. Any suggestion would be greatly appreciated.
Unread 21-02-2014, 22:19
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Only one joystick works when two connected
Check the Diagnostic tab for related error messages about joysticks or refnums.
Check the name given in Begin is exactly the same in Teleop where you are using it.
Better yet, copy the text box from Begin and paste it into Teleop and wire that in.
Unread 21-02-2014, 22:31
FRC #4391
We'll give that a try and let you know how it worked out. thank you.
Unread 23-02-2014, 14:16
FRC #4391
We tried copy the joystick references form begin and using them in teliop with out sucess. still did not work. when looking at the operators console we have no error messages for refnums or joysticks. Puzzling.
Unread 23-02-2014, 14:32
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
I think its the setup tab on the DS, IIRC, that has the joysticks connected to the computer. Check to see if they are listed and if they are in the correct slots 1 and 2.
Just Itinerant
If you want to attach your vi's for Begin & Teleop we can check them out.
