Go to Post The JVN/Karthik segment should have more than enough spontaneity for everyone - Matt Krass [more]
Unread 23-02-2014, 19:00
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
44006 error - please help...
Things were working fine.
Now suddenly I have this error.
Warning <Code> 44006 occurred at Driver Station
<time>2/23/2014 2:57:34 PM<unique#>1
FRC: Custom I/O is not enabled or is not connected to the driver station.
Enet, Bridge, Robot are green.
I can ping and ftp to the robot.
but communications / robot code lights stay red.
I've:
-rebooted the cRIO
-rebooted the driver station
-re-deployed code to the cRIO
Unread 23-02-2014, 19:08
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: 44006 error - please help...
-44006 is just a warning that the Cypress IO board isn't being detected.
Not unusual if you aren't using the Cypress board.
The status lights you report mean that the DS and ping the cRIO and robot bridge.
The lack of Communication/Robot code lights means the cRIO image is not running. (P.S. or in this case the DS is not connecting)
Do you have the NoApp switch set?
It's on the face of an 8-slot cRIO, or on a 4-slot is checked with the cRIO Imaging Tool.
Fire up NetConsole to see if any error messages get reported when the cRIO is booted.
Unread 23-02-2014, 22:56
FRC #3045
Mark,
Thank you for the advice. It turns out to be a bit more subtle than I first indicated.
It probably is related to TCP / IP settings. I accidentally found out that one other machine on the network _can_ communicate. The machine that failed had been working, but then failed for no apparent reason in the middle of the afternoon.
I also learned that, if _one_ machine has the Driver Station running, then no other machines can connect as Driver Station. This shouldn't surprise me, in hindsight.
Amusingly enough, the machine that fails can still upload code and FTP to the cRIO.
Best,
Martin
Unread 24-02-2014, 09:00
Just Itinerant
Yep, the second Driver Station is expected behavior.
First DS to connect wins.
I've experienced that problem at demos when a programmer doing separate work fires up a second DS and blocks the driver's controls DS when it comes up later.
As well, any number of other PCs can connect to upload code or monitor the cRIO.
For instance, the default setup is expected to be:
  • DS wired on .5
  • DS wireless on .9
  • Programming PC on .6
But in the shop any number of extra PCs can be .6 or higher
At the event it's:
  • DS wired on .5 (playing field & pit)
  • Programming PC on .6 or higher (in the pit only)
