Go to Post I, for one, am perfect and therefore make no mistakes. (Unless you count all the times that I completely screw up) - Molten [more]
  #16   Spotlight this post!
Unread 24-02-2014, 14:55
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Reducing Friction in Shooter
Originally Posted by mott View Post
Isn't this the same as having more spring power on the shooting mechanism itself?
Maybe I'm misunderstanding this suggestion...
This is a reasonable solution if the drawback motor/gearbox has additional pulling capacity over what they are currently using but I assumed not.
The main difference is you anchor it to the frame rather than the catapult arm. This allows you use one set of spring force to overcome the intertia of the shooting arm, and another set of spring force to overcome the intertia of the winch being wound back.
All in all, this is fairly useless unless you can move to a larger winch spool diameter, 1/2" is not enough you should go to at least 1", ideally 2"
  #17   Spotlight this post!
Unread 24-02-2014, 15:02
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
Ok, I understand what you're saying but assuming your overall "load" on the motor/gearbox is limited to some maximum, wouldn't you be better off attaching ALL of the springs directly to the launcher so that every bit of energy not needed to overcome the inertia of the winch would be available to put into the shooting arm (instead of being wasted pulling on a frame member)?
  #18   Spotlight this post!
Unread 24-02-2014, 15:11
Chris is me's Avatar
AKA: Pinecone
This is probably obvious, but I just wanted to make clear to the OP - increasing the winch drum diameter will increase your speed at the expense of torque. Think of it like the opposite of a gear reduction. That said, the greater diameter the winch drum is, the greater torque your spring force will put on the output shaft upon release.
A quick and dirty way to make a bigger winch is to throw some hex hubs on the shaft, the kind normally used for sprockets and wheels.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
  #19   Spotlight this post!
Unread 24-02-2014, 16:21
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Does your spool have sides on it that rotate with the shaft to contain the cable/strap/cord?
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
