Go to Post So does this mean we can use the FP as bumpers? :D - Peter Matteson [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 24-02-2014, 14:34
Cbastias4966 Cbastias4966 is offline
FRC #4966
Cbastias4966 is an unknown quantity at this point
automatic IP FRC team changer by:CFR #4966
Hi:
My name is camilo, from condor force robot (Chile). We created a application that change the ip of your team for connect to the crio automatically, without enter to control panel, and network configuration.This application decreases the work of configuring your ip every moment that you want connect to the robot,it's more quickly.
Application only runs in windows 7 and windows 8.
download here
PD: any problem, contact to cbastias@condorforcerobot.cl
thanks.
atte
Camilo Bastias
#4966
Condor Force robot
Unread 24-02-2014, 18:46
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
Rookie Year: 2012
AlexBrinister will become famous soon enough
Re: automatic IP FRC team changer by:CFR #4966
You could just write a batch script for that.
Code:
netsh interface ip set address "<interface name>" static <addr> <netmask> <gateway>
netsh interface ip set dns "<interface name>" static <dns_addr>
Make a file called robotIp.bat and run as Admin
Alex Brinister
Unread 24-02-2014, 19:23
FRC #4966
Code:
Alex Brinister
this .exe do that, without edit the batch script
Unread 24-02-2014, 19:27
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
the driver station already does it as well i believe
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 24-02-2014, 19:54
The driver station checks the IP info -- using netsh. If it doesn't meet the expected settings, it will set it to a static IP.
It does not automatically restore the settings, but it does create a restore file and script in the Public Documents directory named "FRC Restore My Network Settings.bat".
You could pretty easily put an alias to it on the desktop.
Greg McKaskle
Unread 26-02-2014, 01:23
AlexanderTheOK AlexanderTheOK is offline
Guy
Rookie Year: 2012
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
The script the driver station uses doesn't revert the IP settings back to dhcp as far as I remember, you'd have to make that part with your own batch file. Its a pretty simple command though:
Code:
 netsh interface ip set address "<your internet name>" dhcp
I think thats right. My sleep schedule has been wrecked lately but I think that't it.
Unread 27-02-2014, 06:03
If the DS changes the IP settings, it performs a dump to a text file. It doesn't explicitly set the PC to DHCP, but attempts to restore it to how it initially found it. Originally, it was going to restore when quitting, but this was actually quite annoying, especially on a programming laptop. This step needed to be independent of the DS.
Below is the documentation on dump. I haven't used it in years.
Greg McKaskle
C:\Windows\system32>netsh interface ip dump /?
Usage: dump
Remarks:
Creates a script that contains the current configuration. If saved to a
file, this script can be used to restore altered configuration settings.
