Go to Post As usual, I mistakenly look for a technical solution to a social problem. - MrForbes [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 24-02-2014, 16:24
WIREDFTC's Avatar
WIREDFTC WIREDFTC is offline
More hot glue!
FTC #5035 (WIRED)
Team Role: Webmaster
WIREDFTC has a spectacular aura aboutWIREDFTC has a spectacular aura about
Sheet Metal Parts
Is there any way to fabricate a sheet metal part that has flanges which are offset from the edges of the face without it putting the small notches on the face like this? (Not my picture, had problems uploading one, but it's the same general idea) I don't need them, but I still want the part in the sheet metal generator so I can get a flat pattern, otherwise I would just use the bend tool in a normal part.
Unread 24-02-2014, 16:56
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Sheet Metal Parts
You should be able to change the bend position.
To get what you want, select the option so it places the bend outside of the face.
Like this:
http://www.chiefdelphi.com/forums/at...d=13932788 69
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 25-02-2014, 18:02
WIREDFTC's Avatar
More hot glue!
FTC #5035 (WIRED)
Hmm. I swear I tried that before, but it worked, so thanks!
