Thread Tools |
Rating:
Display Modes |
Re: [FRCTop25.com] Week 1 Preview Show!
After autonomous, there is quite a bit of variance on how things could play out depending on that third robot's capability to synergize well with the other high seed robots in just one facet of the game. That could be shooting, outlet passing, defense, etc. This will require the other two robots to be very versatile in their skill sets in order to accomodate the vast array of possibilities for that third alliance partner capability. If the top robots are too one dimensional or too hesitant to adjust their playstyle based on their partners, I think that's the recipe for top seeds getting upset. |
I agree that 2 ball is not as rare as multi disc auto was last year...but that doesn't mean you can assume to see 1/3 of a regional roster to have that ability either. |
A lot of these reveal videos only show you the times it made it, not the failed attempts before and/or after. However, I would say it would be a good idea for ALL teams to come up with an autonomous mode that will do nothing for about 7-9 seconds (depending on how fast you can get to the forward zone) and then drive forward, in order to be able to better take advantage of these multi-ball autonomous modes. Even if you think your robot is too good to not shoot it's own ball, mechanical failures happen. If you find your shooter broken going into the match and your alliance partner can cover for it in autonomous, you will be glad you were prepared. |
Could be worse, like getting banned for no reason and not even knowing.
will there be an archive of the show somewhere for anyone who may not be able to tune in live?
This is also a great time to mention that we have moved one more final time. You can catch tonight's show at new.livestream.com/FRCTop25. Can't wait to see you all tonight! |
I agree multi-ball auto is featured in quite a few reveals. However, who is programming an auto mode that is "leave the ball and go for the colored zone?" I mean balls have to touch a robot and very few videos have shown that. They simply start with two balls in the vicinity of their machine.
They do if you want the 5 mobility points.
#11
Please, please point me to the rule that says I MUST load a ball for Mobility points.
#12
Actually, Eric, you may want to double check the wording of G5...
"G5 For ROBOTS starting in the white ZONE, the TEAM may preload one (1) of their ALLIANCE’s BALLS such that the BALL is touching their ROBOT. For ROBOTS starting in their GOALIE ZONE the TEAM may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH. If a ROBOT does not report to a MATCH, its ALLIANCE may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH. Violation: If the situation is not corrected before the start of the MATCH, TECHNICAL FOUL per BALL improperly staged." I've interpretted that as in order for a ball to be placed on the field in autonomous, it must be touching a robot to be considered 'loaded'. Exception, of course, is if you place that robot in the goalie zone. That means, if you've already loaded your robot with a ball, you have to place a robot you may be 2 balling with such that it is in contact with that ball and you are not. Again, unless the robot that ball 'belongs' to is positioned in the goalie zone. At least that how I've interpretted it. Did I interpret that wrong? If you were only referring to the goalie zone instance, then feel free to kick me when you see me in Milwaukee. lol ![]() Last edited by barn34 : 25-02-2014 at 16:39. |
#13
#14
