Go to Post BTW don't trust game hint threads started by Greg Needel. - rtfgnow [more]
Unread 25-02-2014, 10:18
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Terminal Velocity
Because of its size and low density, it seems that air drag should have a substantial effect on the flight path of this year's game piece.
Has anyone tried measuring the ball's terminal velocity? Various web sites predict a value in the mid-to-upper thirties (feet/sec) for a sphere of its size and density.
If this is indeed the case, the effect on flight path is indeed substantial, as can be seen in the parabola vs air drag attachment located here.
Unread 27-02-2014, 09:36
Ether's Avatar
Rookie Year: 1969
Re: Terminal Velocity
FWIW, you can add a cubic trendline to the air_drag trajectory and get a very good fit.
ID:	16390  Click image for larger version
ID:	16391  Click image for larger version
Unread 27-02-2014, 10:41
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Interesting graphs Ether. They tend to jive with the real world experience of the ~11ft long "Aren Hill Sweet Spot" from ~7-~18ft out.
