Go to Post We like to help, otherwise they put us back in our cages. - Matt Krass [more]
Unread 26-02-2014, 17:16
Just_In_Time Just_In_Time is offline
Rookie Year: 2010
Just_In_Time is an unknown quantity at this point
[FTC]: Use Tetrix Encoders to Hold Positions?
Hello. I recently installed some encoders on our robot's arm in the hopes that I could press a button to allow the arm to go to a certain position regardless of the previous position the arm was at, essentially the same thing one would do with a servo. However, when I tried using Encoder Target Distances, it simply went in one direction for however many rotations instead of rotating back to the same position. Does anyone know of a way that I could accomplish this so the Tetrix motor acts like a servo and returns to a previously set position? Any help is greatly appreciated. Thanks.
JIT
Unread 26-02-2014, 18:25
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: [FTC]: Use Tetrix Encoders to Hold Positions?
RobotC, or Labview??
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 26-02-2014, 18:27
Rookie Year: 2010
RobotC
Unread 27-02-2014, 10:47
If you post your problem/idea here, alot more people can help out with your programming.
http://www.robotc.net/forums/viewfor...d016402 c758b
www.valleyx2844.com
Unread 06-03-2014, 12:39
Wingus&Dingus Wingus&Dingus is offline
FTC #7440
Wingus&Dingus is an unknown quantity at this point
JIT
From memory the Encoder Target Distance function only works with the LEGO motors. You'll need to implement (at least) a Proportional controller which measures the arm position and adjusts motor power according to the error between your Set Point and the Current Position. Also the PID controller built into HiTechnic DC Motor controllers didn't work out for us in a past season so we ended up writing our own. It all seems like partial implementations in these motor controllers which is frustrating.
