Go to Post And Dave, although I know you have connections, please don't slow the earth's rotation to get more time on the caption contest. ;) - Billfred [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 00:56
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Solenoid Wires
Posted by AJ Howard at 2/15/2001 4:02 PM EST
Other on team #316 from Salem County.
The Solenoid uses 24 AWG wires. Why do you have to use 16 AWG wires to run from the relay to the solenoid.
Thank You
Team 316
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
because the rules say so
Posted by Joe Ross at 2/15/2001 8:41 PM EST
Engineer on team #330, Beach Bot, from Hope Chapel Academy and NASA/JPL , J&F Machine, and Raytheon.
In Reply to: Solenoid Wires
Posted by AJ Howard on 2/15/2001 4:02 PM EST:
: The Solenoid uses 24 AWG wires. Why do you have to use 16 AWG wires to run from the relay to the solenoid.
FIRST always trys to be conservative with the wire sizes. It is much better to be safe than sorry and not every team has someone who can calculate the safe wire size.
#0047 (ChiefDelphi)
Re: Solenoid Wires - and, the rules are written so that ..
Posted by Lloyd Burns at 2/16/2001 7:53 AM EST
Other on team #188, Woburn Robotics, from Woburn Collegiate and Canada 3000, ScotiaBank, Royal Bank Financial.
: Thank You
: Team 316
Imagine that your robot is "impacted" by a falling 20 year old Russian satellite (since FIRST robots _never_ bang into each other): the wires to your solenoid are severed and shorted. With thin 24 AWG wires, the wire gets hot and fuses, perhaps at several places along the length, causing potential fire hazard. With thick 16 AWG wire, before the wire heats up, the circuit breaker cuts out and disconnects the circuit. :-)
[IMG] code is Off
extra 40amp wires Lord Nerdlinger Electrical 4 14-02-2003 14:53
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
Does anyone have extra solenoid valves????? Elgin Clock Pneumatics 5 18-02-2002 12:43
Can we ground our wires to the frame? mnkysp6353 Electrical 1 15-02-2002 20:47
