Go to Post Get your team together. Get your priorities straight. Get busy having fun. See you on the field. - EricH [more]
Unread 27-02-2014, 19:33
twignation twignation is offline
FRC #3616
twignation is an unknown quantity at this point
Vision Targeting Problems
In the Target Ditection VI, the target is showing up in the mask, but it is not being recognized as active, that is, it is not drawing any boxes around it.
Unread 27-02-2014, 20:51
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Vision Targeting Problems
Where's the vertical stripe? I think the code needs that to identify it as a target.
Unread 27-02-2014, 22:10
FRC #3616
We are trying to get the horizontal reflective tape. The mask shows it in red but it does not draw a green or red box around it at any time. It does draw red boxes for other things such as shiny metal or my hand. We'll try the vertical stripe tomorrow to see if it makes a difference.
Unread 01-03-2014, 12:22
First, I'd compare the size of the particle to the size limit parameter. Also look at the array of target descriptors to see if the issue is only with drawing the annotation.
Greg McKaskle
Unread 02-03-2014, 23:18
FRC #3616
Thanks for the responses, we resolved the issue by creating the vertical stripe to go along with it.
