Go to Post We can't be afraid to critique the existing system. If we don't, how will it ever get better? - Jaine Perotti [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 28-02-2014, 04:21
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
Rookie Year: 2012
sparkytwd will become famous soon enough
ocupus for Odroid XU sd card image
Earlier this season I announced a project I've been working on with FRC3574 to better manage streaming video.
If you have an Odroid-XU, you can try out the full system image here: https://mega.co.nz/#!YRwQVAKL!95CGjj...hP9eqydU s2lw
Flashing is best done from a Linux box, as you will need gparted resize the root partition
sudo xzcat ocupus.beta1.odroidxu.img.xz | sudo dd of=/dev/sdX bs=4M
sudo gparted /dev/sdX
Then resize the second partition to take up the rest of the space.
You will then need to edit the network.cfg file on the first partition, which can be done from Windows. Change the 35.74 address to match your team #.
Plug in a USB camera, then power up your Odroid attached either to your 10.XX.XX network or one with DHCP.
Visit http://<odroid-ip>:5000 to watch the streams
Unread 28-02-2014, 13:35
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
Team Role: Coach
Rookie Year: 2007
steinra is on a distinguished road
Re: ocupus for Odroid XU sd card image
Thanks for the share! We have the new U3 we were going to use, but just ran out of time, but we might give this a quick shot and see if we can still squeak it in (also a little close on weight )
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
Unread 28-02-2014, 14:43
sparkytwd's Avatar
FRC #3574
Rookie Year: 2012
That's awesome. Just FYI this is for the XU, I don't believe it's compatible with the U3. That being said, last night I just wrapped up building the v4l2loopback kernel driver for it, so I should have a U3 image soon!
