Go to Post The "line" is the point at which we've raised the floor so high that the advanced teams are hitting the ceiling. The ceiling is pretty darned high (and the GDC keeps raising it), so I don't think we're in danger of that any time soon. - EricVanWyk [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 28-02-2014, 16:30
Laxkief9098 Laxkief9098 is offline
FRC #4557
Laxkief9098 is an unknown quantity at this point
AndyMark Example code not working
We just purchased an LED package with from andymark with a part number of am-2645. We have tried downloading the code to the contoler provided in the package which we have gotten off of github. When we try to download the code we receive the following errors:
sketch_feb28a:9: error: stray '#' in program
sketch_feb28a:13: error: stray '#' in program
sketch_feb28a:18: error: stray '#' in program
sketch_feb28a:21: error: stray '#' in program
sketch_feb28a:1: error: expected unqualified-id before '+' token
sketch_feb28a:25: error: expected unqualified-id before '+' token
sketch_feb28a:49: error: expected unqualified-id before '+' token
sketch_feb28a:68: error: expected unqualified-id before '+' token
Here is the code itself:
@@ -0,0 +1,113 @@
+ //This is a mashup of FastSPI_LED2 firstlight example and some other light chase hacks
+ //AndyMark, LLC
+ //Craig Kessler 12/3/2013
+ //Works with the AndyMark AM-2640 LED Strip based on the WS2801 chipset
+ //This code requires that the fastspi library be put in your arduino\libraries folder
+ //https://code.google.com/p/fastspi/
+ //https://code.google.com/p/fastspi/wiki/CRGBreference
+ #include "FastSPI_LED2.h"
+ // How many leds are in the strip? AndyMark's 2.5 meter strip has 80 leds
+ #define NUM_LEDS 80
+ //Remember on the AM-2640 LED strips yellow is ground! (don't blame us they come that way)
+ // Data pin that led data will be written out over
+ #define DATA_PIN 11 //Green Wire
+ // Clock pin only needed for SPI based chipsets
+ #define CLOCK_PIN 13 //Blue Wire
+ // This is an array of leds. One item for each led in your strip.
+ CRGB leds[NUM_LEDS];
+ // This function sets up the leds and tells the controller about them
+ void setup() {
+ // sanity check delay - allows reprogramming if accidentally blowing power w/leds
+ delay(2000);
+ // Uncomment one of the following lines for your leds arrangement.
+ // FastLED.addLeds<TM1803, DATA_PIN, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<TM1804, DATA_PIN, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<TM1809, DATA_PIN, RGB>(leds, NUM_LEDS);
+ //FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<UCS1903, DATA_PIN, RGB>(leds, NUM_LEDS);
+ FastLED.addLeds<WS2801, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<SM16716, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<LPD8806, RGB>(leds, NUM_LEDS);
+ //FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<SM16716, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
+ // FastLED.addLeds<LPD8806, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
+ // This function runs over and over, and is where you do the magic to light
+ // your leds.
+ void loop()
+ color_chase(CRGB::Green, 10);
+ color_chase(CRGB::BlueViolet, 10);
+ CRGB temp_rgb;
+ CHSV hsv(215,255,255);
+ hsv2rgb_rainbow(hsv, temp_rgb);
+ missing_dot_chase(CRGB::White, 25);
+ missing_dot_chase(CRGB::Red, 25);
+ missing_dot_chase(CRGB::Yellow, 25);
+ missing_dot_chase(CRGB::Green, 25);
+ missing_dot_chase(CRGB::Cyan, 25);
+ missing_dot_chase(CRGB::Blue, 25);
+ missing_dot_chase(0x3000cc, 25) ;
+ void color_chase(uint32_t color, uint8_t wait)
+ FastLED.clear();
+ FastLED.setBrightness(100);
+ // Move a single led
+ for(int led_number = 0; led_number < NUM_LEDS; led_number++)
+ // Turn our current led ON, then show the leds
+ leds[led_number] = color;
+ // Show the leds (only one of which is set to white, from above)
+ FastLED.show();
+ // Wait a little bit
+ delay(50);
+ // Turn our current led back to black for the next loop around
+ leds[led_number] = CRGB::Black;
+ //Move an "empty" dot down the strip
+ void missing_dot_chase(uint32_t color, uint8_t wait)
+ int led_number;
+ for (int led_brightness = 100; led_brightness > 10; led_brightness/=2)
+ FastLED.setBrightness(led_brightness);
+ // Start by turning all pixels on:
+ for(led_number = 0; led_number < NUM_LEDS; led_number++) leds[led_number] = color;
+ // Then display one pixel at a time:
+ leds[led_number] = CRGB::Black; // Set new pixel 'off'
+ if( led_number > 0 && led_number < NUM_LEDS)
+ leds[led_number-1] = color; // Set previous pixel 'on'
+ FastLED.show();
+ delay(wait);
