Java wait Function
What we want to do is to have our solenoids to open and then after like 0.5 seconds have it close automatically.
This is our code so far: Code:
if (j_shooting.getRawButton(2)){ //FORWARD - BUTTON A
flag = 1;
}else if (j_shooting.getRawButton(1)){ //BACKWARD - BUTTON X
cyl_shoot.set(DoubleSolenoid.Value.kForward);
}else {
cyl_shoot.set(DoubleSolenoid.Value.kOff);
if (flag == 1){
cyl_shoot.set(DoubleSolenoid.Value.kReverse);
try {
Thread.sleep(500);
} catch (InterruptedException ex) {
ex.printStackTrace();
flag = 0;
So my question is, is the code i have right now good and if not what other options is there to have the pistons open, pause for 0.5 seconds, and then close. thanks |
Re: Java wait Function
Thread.sleep() causes the current thread to pause for a time. If you call this from the main thread, the robot will be unresponsive for those 500 ms while the thread sleeps. You could avoid this by moving the solenoid code to a separate thread.
A simpler option that I often use is to record a timestamp at the start and then subtract that timestamp from future readings to get the elapsed time. Example: Code:
double startTime;
if (j_shooting.getRawButton(2)) {
// This will repeatedly be set until you let go of the button
startTime = System.currentTimeMillis();
} else if (j_shooting.getRawButton(1))
// This will override, but not reset, the timer
} else {
// Check the time to see if the pistons should be...
if (System.currentTimeMillis() - startTime < 0.5) {
cyl_shoot.set(DoubleSolenoid.Value.kReverse); // ...extended, or...
} else {
cyl_shoot.set(DoubleSolenoid.Value.kForward); // ..retracted
Timer.delay() is supposed to leave outputs set where they are as well, but I've had more success using Timer.getFPGATimestamp() in conjunction with a loop.
Our team had similar requirements surrounding our catapult (do X, wait half a second, then do Y). Originally the programmers implemented this using Timer.delay(). The result was that when the drivers tried to perform the action while moving, but then stopped moving or changed directions during the action, the robot would keep moving. Though .5 seconds doesn't sound like much, it is plenty of time for your robot to go just a little too far and injure someone, break something, or get you a penalty for going too far outside the arena. Use Timer.delay() with caution. |
^This.
Year in and year out I see programmers bumping up against this concept. I think it's probably fair to say that some (many?) of them receive advice on how to fix the problem, but never really understand why there was a problem and why the fix fixed it. Does anyone have a link to a clear, simple, well-written tutorial on concurrent processing for FRC that covers threads, state machines, and interrupts? Last edited by Ether : 01-03-2014 at 13:18. |
This is what I have done.
Inside op control: Code:
if(INSERT SOMETHING HERE) {
new Thread() {
public void run() {
//Code to run here:
Thread.sleep(time in ms);
//More code
}.start()
This has worked well for me. Hope this helps! Matt |
how does the thread get killed?
My understanding is that the JVM handles it. From here, it seems like letting the JVM handle could introduce race conditions if you access the same data from multiple threads like that...
Alex Brinister |
ah. looked at it too fast. The thread completes normally when run() returns.
#10
Is safety configured for the drive base? I'd hope that the Java implementation would halt the drive motors when wait() or breakpoints delay for more than 100ms.
Greg McKaskle |
#11
I think this is only enforced if you have the Motor Safety Helper enabled. This feature is optional in both the C++ and Java libraries and can be disabled by the programmer. It is generally better to keep it enabled but to extend the timeout period using the SetTimeout() function in whatever motor controller class you choose to use (Talon, Victor, CANJaguar, Jaguar, etc).
Alex Brinister |
#12
This causes the calling thread to sleep, and thus will cause your robot to hang unless called from a separate thread. Use time stamps as mentioned. System.getCurrentTimeMillis, or the FPGA timer, or anything else in a loop, or spawn a separate thread and call thread.sleep() in the new thread. But do not call Thread.sleep or Timer.Delay in the same thread as your TeleOp/Auto periodic functions. Hope this helps, Kevin |
