Thread Tools |
Rating:
Display Modes |
Re: Propose possible fixes for high goals
I think it's totally fair. It's just all part of the design challenge. It probably is hard to change the trajectory of a catapult and do all the math associated with it, but that's one of the reasons why we didn't design a catapult.
If nothing is going to be changed about the bar, then things need to change about how cycles are ended. Refs should be able to undo cycles since the ball is literally bouncing out of the goal after it appears to be scored. Maybe have another set of lights on the human barrier station so if the cycle is undone, the human players can't inbound until those lights are lit as well. As a ref, I will not want to cause a field fault due to unscoring balls, but I also want to make sure that the next cycle is started as soon as possible. Honestly, this bar seems more unfair to refs, than to the robots.
Even if the bar was deemed unfair by the GDC itself, nothing would be done about it, and it's not mainly because of money. The main problem is that in the week one events, the teams who participated had to deal with the bar. Changing that bar is not fair to them. If they had to deal with it, it's more fair that everyone else has to deal with it as well. They had to adjust and so do we, simple as that.
It's not a rule, it's a field element.
FIRST has changed field elements before also... this whole discussion sounds remarkably like the discussion early in 2012 when basketballs wouldn't roll out from under the bridges.
Then, FIRST made a change to the way they attached the polycarb ball ramps to the underside of the bridge assembly (if I remember correctly). |
They've changed the field before too. Remember in 2012 they changed the polycarb under the bridges after balls would get stuck under them, so only certain robots could pick them up. I'm pretty sure this was between week 1 and week 2.
Honestly if it becomes a larger issue, more than refs trying to keep score and what have you, they could probably just use cardboard... I don't think it had made that big of an impact YET.
#10
Also about the bar...
Even if FIRST wanted to, let's think about the logistical nightmare of getting the materials to fix the fields out to all the events. This weekend alone, there were 11 fields deployed across the U.S. and Canada, and there's certainly more fields then that. Once fields leave HQ, they don't return until the end of the season. So for a fix to happen, the materials would have to be shipped all over the place. While this could be done, I'd be willing to be HQ would try to avoid it as much as possible. Edit: Not saying it can't be done, or hasn't been done (I do remember 2012), just making sure people are aware of the logistics of making the change happen. Last edited by dag0620 : 02-03-2014 at 16:08. |
#11
Tell that to CHAOS 131, whose close, high angle, "layup" shot got stuffed by the bar probably more than a dozen times at GSDE. It was really unfortunate, because they had a great machine, but lost matches due to this field feature.
#12
Many times the ball would go through the high goal and settle resting on the bar in the rear until someone took it down. This must have been disruptive for the drivers in that station.
Also the field drawings did not reflect the bar in the back. To me this is a different challenge than what was presented and should be fixed. I helped set up the field at GSDE and can say that the polycarbonate idea would be very easy to implement. |
#13
All teams have to deal with this issue, so it is fair. I suggest, instead of wasting energy complaining about it, work to figure out a way so that your robot is less affected by it. Griping about a field element that has been in the drawings since kickoff is wasted energy IM(NS)HO. |
