Thread Tools |
Rating:
Display Modes |
Re: 2014 Alliance Selection Results
Does anyone have the selections from the Israel regional?
Israel Regional:
1) 3316, 1574, 3065 2) 3211, 3339, 2212 3) 2231, 1577, 1690 4) 2630, 4320, 5135 5) 1937, 5038, 2230 6) 2679, 4586, 4590 7) 1946, 4744, 1942 8) 4649, 4406, 1836 |
Added results... no declines.
UNH District Event
Code:
1) 176, 131, 3597 2) 319, 213, 3280 3) 3467, 58, 4555 4) 509, 1058, 69 5) 4958, 166, 348 6) 3499, 1761, 3451 7) 3479, 4925, 126 8) 3236, 3323, 1073 |
Confirmed and results added.
Central IL
1. 525 1986 4296 W 2. 1736 2481 4213 QF (1806 declined 1736's offer) 3. 1806 2451 1094 QF 4. 1756 967 1288 SF 5. 1747 3284 3138 QF 6. 171 4143 2039 F 7. 2081 2022 292 SF 8. 167 1208 4256 QF Last edited by avanboekel : 01-03-2014 at 16:59. |
Center Line
#1 1023, 1718, 4776 (QF) #2 4810, 1189, 2673 (SF) #3 494, 4130, 5225 (QF) #4 818, 302, 4815 (QF) #5 2851, 910, 5214 (SF) #6 815, 3175, 280 (F) #7 123, 217, 2591 (QF) #8 4779, 3667, 453 (W) No declines Last edited by Basel A : 01-03-2014 at 23:34. |
There was a field problem which gave a replay in SF - 2, which changed the result.
We were in Northern Lights but someone already posted that so here is Lake Superior:
1)3313, 706, 3883 (finalist) 2)3018, 2052, 3692 (winner) 3)4845, 1714, 5299 4)4539, 3755, 3277 5)3102, 2977, 2177 6)5290, 4009, 4818 7)3042, 3061, 2526 8)2472, 1816, 93 DoubleDECCer result 3018, 2052, 3692 vs. 2175, 369, 2502 Winners: 2175,369, 2502 |
#10
Central Valley - Editing Live (Completed)
1)254, 973, 2135(W) 2)1671, 1323, 3970(F) 3)696, 2443, 1422(SF) 4)3562, 2761, 5102(QF) 5)649, 2073, 3501(SF) 6)3120, 670, 3482(QF) 7)2637, 2085, 5136(QF) 8)256, 3512, 2643(QF) No Declines # of Matches Played QF1-In 2 QF2-In 3 QF3-In 3 QF4-In 2 SF1-In 2.5(Match replayed) SF2-In 2 Final-In 3 Last edited by orangemoore : 09-03-2014 at 20:26. |
#11
2)3018, 2052, 3692 (W) 3)4845, 1714, 5299 (QF) 4)4539, 3755, 3277 (SF) 5)3102, 2977, 2177 (QF) 6)5290, 4009, 4818 (SF) 7)3042, 3061, 2526 (QF) 8)2472, 1816, 93 (QF) 1 decline: 2472 declined 3042 I've only been in FIRST for 4 years but the Elims at Lake Superior were the most insane, tense, close matches I have ever seen personally. The first 4 QF matches were all decided by less than 14 points. Each match was intense from beginning to end. Every single matchup (except SF-2) went to 3 games. EVERY SINGLE ONE. The #1 Alliance (that would be us) originally lost the 3rd QF match but because of a pedestal not lighting up, we got a second chance and won. Elims were a defensive war of attrition. 706 got their pick up arms bent 4 different times. 3313 tipped over, broke our side panels, and had our electrical board drag on the ground the last Finals match. 2052 broke their shooter in the SF and still ended up being champions. 1816 had to fix their shooter. 3018 had a radio go flying. And those are just the stories I've heard. I am 100% sure there are many others. 3313 ended up playing 24 matches in one weekend including 10 Elimination matches. Not sure often that happens. It was awesome. Last edited by MrBydlon : 10-03-2014 at 01:28. Reason: Too tired |
#12
Okay, I don't know why somebody would want to do that. Most of the data were deleted today. I found at least one team number that got changed to a wrong number. It is okay for me since I already copied the data out last night.
Joe Ross and I also found two typos in these lists of teams. It has been corrected. It did not affect my database because my program searched through the elimination results to try to figure out on its own what the selection order is. It only relies on this Google spreadsheet data if needed. In both typo errors, my program recognized the error and ignored it. I really appreciate everybody who helped put these data in. Please do not try to type this in manually. It is very easy to make a mistake. Assuming the list on this CD post is correct since if it is not, a lot of people will point it out. The better way to do it is copy the text on the CD post, paste it into Notepad. Then select all and copy. Then go to a new Excel sheet and paste using Text Import Wizard. Depending on if the person use "," or "-" or space, select the Delimiters that were used, then all the teams will be in the spreadsheet. Then copy the team numbers and paste it into the converter in the Google spreadsheet. This way it will minimize the typo. Thanks everybody! ![]() |
#13
Yeah... Team #3692 at one point got hit so hard it actually physically disconnected the battery cable. (that was in 2nd round of the finals, which was the same round our alliance partner also had their router fly out)... so we had 2 robots down that match, man was that scary...
![]() Let me tell you, can those kids fix things really fast when they are motivated... it was like watching Nascar pit crews.. only better! Quote:
#14
WPI District (New England)
1. 716 885 4169 2. 1350 4564 1687 3. 4909 4048 4906 4. 2423 2370 1768 5. 2648 5122 811 6. 4473 190 2877 7. 4905 1735 839 8. 61 3623 3930 No Declines |
#15
3 vs 6 looks like a good matchup. How did 190 fall so far?
