Go to Post If you see Navy ships in port, you're going to be fine. If you see ships pulling out, or no ships at all, go East. Fast. - Matt Howard [more]
Unread 02-03-2014, 00:28
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Question Has FIRST canceled tie breaker matches in eliminations??
Re-reading the manual:
5.4.4 Elimination Scoring
In the Elimination MATCHES, Teams do not earn Qualification Points; they earn a Win, Loss or Tie. Within each series of the Elimination MATCH bracket, the first ALLIANCE to win two (2) MATCHES will advance.
In the case where the MATCH score of each ALLIANCE is equal, the tie is broken by awarding an extra point to the ALLIANCE with (in the following order):
highest number of FOUL points awarded (i.e. the ALLIANCE that played the cleaner MATCH)
if FOUL points are equal, highest number of ASSIST points
if ASSIST points are equal, highest number of AUTO points
if AUTO points are equal, highest sum of TRUSS and CATCH points
If the criteria above are equal, the MATCH is a Tie. Additional matches will be played if needed.
emphasis mine.
How long has this rule been this way?? are the officials simply ignoring it and playing tie breaker matches?
Clarification would be welcome!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 02-03-2014, 00:32
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: Has FIRST canceled tie breaker matches in eliminations??
emphasis mine.
-Leav
I think they started this practice in 2012. 2010 was notorious for tied matches in eliminations, sometimes the finals would go up to 5 matches, so they decided to go to a tiebreaker.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 02-03-2014, 00:33
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The rule has been that way since 2011. Or at least, quite similar--typically, clean match, then the other objectives in order.
I would guess that many of the various replays are due to field faults rather than true ties--but I could also see true ties happening quite often.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 02-03-2014, 00:55
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
So:
  • Blue Win
  • Red Win
  • Tie
would result in advancement based on who played cleaner matches?
has anyone seen this happen at elimination matches?
-Paraphrasing JFK
Unread 02-03-2014, 00:57
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Another match should be played because of how the rule is written.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 02-03-2014, 01:49
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
There was a tie during Elims at Centerline today, and they followed the rule to the letter. Blue committed a foul, so Red was advanced.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 02-03-2014, 02:45
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Same happened at the Southfield district also today... Since there were no foul points, it went to the most assist points..
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 02-03-2014, 04:36
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
So:
  • Blue Win
  • Red Win
  • Tie
The tiebreaker is for a tied match. A series is still best 2 of 3.
Mentor http://www.teamtitanium.org/
Unread 02-03-2014, 04:43
JosephC's Avatar
Rookie Year: 2011
He's saying Blue won the first match, Red won the second, and then they tied the third match.
Referee: 2015 - ?
Unread 02-03-2014, 04:58
Doh! I guess I shouldn't be posting while trying to sleep in a bus parked in a Wal-Mart parking lot. We're waiting for the storm to pass and I70 to get cleared.
Sorry.
Unread 02-03-2014, 16:27
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
This actually did help me understand the situation better.
so the tie breaker is for a tied match, and a single point would be added to that match's score based on the cleaner match, etc.
good to know!
-Paraphrasing JFK
Unread 02-03-2014, 22:02
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
Also was used at Mt. Olive in the Semi-Finals. After refs decided to replay a third-round match, the replay score resulted in a tie. This rule was followed, it was a clean match (no penalties), and one point was added to the team with the greater assist points.
