Thread Tools |
Rating:
Display Modes |
Re: Game piece inflation
We really should not have a problem putting a ball in a box and pumping it up till it touches the sides.
I don't see why you can't just pump them up in the morning and check them at lunch each day and be done. Or even just once a day (I'm assuming they may lose some air getting hit and squished all day). The rules say approximately 2ft diameter. Excuse me for designing for 23"-25". |
They were extremely inflated at teh Glacier Peak PNW regional as well. So inflated in fact, that it started to continuously stall our motor and wouldn't allow us to gather the balls at all. We want to put some slop in our pneumatic mounts to our arm to try to fix this problem, any other teams done things to help this problem?
I don't think anyone is asking for 10 decimal places of tolerance on the diameter.... However a single decimal place or 2 would certainly be welcome. Honestly I would take one or the other if it helps consistency in an event and event to event. Right now, we don't have either besides a general 'look' and 'feel'. -Brando |
Remember this video was to address this concern. http://youtu.be/Azc8AKzgEwE
The sportogo makes them as 25" balls, AndyMark sells them as 2' balls. They must loose an inch in Indiana air. ![]() |
If you try to instead control the pressure you'll see that you get stuck with a different ball diameter. |
We in the PNW district did not receive any sizing rings with our fields. I was there in the process of unloading all the stuff we received to inventory it and test it before repacking and loading on the truck. We never saw any such rings. |
After reading this I tried to inflate ours to 25". It would not get any bigger then 24" no matter how much air i put in. (almost to the point of bursting). Are the balls supplied by the field different than the ones supplied in the KOP? I sure hope not.
