Joystick vs. Controller?
We have seen an increase in controller use recently and were wondering what are the differences? What are the pros and cons of each and we would like to hear what you guys like to use best!
Re: Joystick vs. Controller?
Our team uses controllers. One of our sponsors (Create, Cut, and Invent) builds bomb disposal robots for SWAT teams and he claims that using a controller massively improves your reflexes. That said, it's really driver preference.
Controllers are not as restrictive as joysticks because you can use them in the air as opposed to on a tabletop. They also have more axis, which our programmers really like.
In all honesty it's just driver preference, I can almost guarantee you any driver that's using an Xbox controller is because they play Xbox a lot at home. Personally I prefer driving with 1 Attack3 joystick, or Arcade as it's called, because it just seems easiest to steer with and get the most precise movements out of. Also since the buttons are much larger on joysticks the probability of you pressing the wrong button on a joystick is much less.
For swerve drive we were using an Xbox controller and it worked pretty well.
But yesterday, we tried using a Attack3 joystick for strafing and a 3d joystick for rotating. I'm glad we tried that; I actually like the dual joysticks better. For a tank drive last year, we used one 3d joystick Last edited by cjl2625 : 03-03-2014 at 12:08. |
A controller is generally used because the driver will be more familiar with it, there is a second set of triggers (bumpers), and the driver can move around a bit more with it. That being said, thumbsticks generally feel a little awkward for tank drive control but are more comfortable for arcade and omnidirectional control. Also, even though drivers may be comfortable with the controller itself, the amount of time from input to a robot's response is significantly larger than in most video games so there is still some things to get used to.
Joysticks offer a larger range of motion which can prevent the driver from being as erratic as they might be with a controller. They are usually the preferred input for tank controls but still feels comfortable for arcade/omni. Also, drivers usually feel like they can emphasize their input a bit more which is satisfying in intense FRC games. |
Entirely driver preference. I am used to controllers, my brother prefers joysticks.
I used to be in the die-hard two joystick tank drive camp.
This year, 4343s robot is configured with an Xbox controller, and is completely intuitive to drive if you've ever played an Xbox racing game. Pulling the right trigger is gas, left trigger is reverse, left thumbstick to steer. I picked it up and was racing around our shop in seconds. |
Driver preference. Though I will say that this year we have implemented a drive controls transform and scaling on a single xbox controller stick and it's the best-driving robot our team has ever made.
#10
I really prefer strait up two joystick tank drive, we tried cheesey but I didn't like the turns as much, the only way I would try a controller was if it was tank. The only major question we had was whether or not to have an operator use a controller or should it be the triggers on the joysticks. I must say, it is easier to not have them on the joysticks but we felt it was necessary for it to flow properly during matches.
#11
