Go to Post In real life (IE when you go to apply your engineering skills to tasks in industry) there will be constraints on all sorts of things - many of which may or may not be "fair" or even "intelligent". You must learn to either work around them or use them to your advantage - preferably a bit of both. - OScubed [more]
Unread 03-03-2014, 12:45
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
Rookie Year: 2012
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Vision Targeting
Hello! I've been wondering if the vision targeting is any different from last year. Is detecting the hot goals this year the same as detecting the reflective tape around the frisbee goals last year? What I mean by "the same" is "similar to program in Labview". Thanks!
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 03-03-2014, 15:49
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Vision Targeting
It's very similar in that it uses the IMAQ vision tools.
The example vision code is similar in that it does the same sort of "wait for image" and "process image" and "provide results" steps. The exact image processing details are different, of course.
Unread 03-03-2014, 20:58
Greg McKaskle Greg McKaskle is online now
Both 2013 and 2014 image examples are available. You can open both and see how things changed.
Greg McKaskle
Unread 04-03-2014, 07:15
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
There are differences this year that I've noticed:
1) the vision targets are behind the glass in the driver station. If you try to detect them at an angle (like us), the glass kills probably 50% of the light that reflects back to the camera. Bigger angles mean more lost light. Our great camera calibration from our home field was useless at the event. We learned a big lesson there: put some lexan in front of the vision target at home.
2) Delays and flutter in the mechanism that hides the hot-goal indicator result in having to wait a lot longer than we expected to be able to detect which goal is hot. If you're only shooting one ball, it's not a very big deal. If you're trying for multiple balls in hot goals, then this wait becomes significant.
An ounce of perception is worth a pound of obscure.
Unread 04-03-2014, 09:28
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
mwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond repute
Is only the flipping target behind the lexan, or is the fixed/vertical target also behind it?
"Never let your schooling interfere with your education" -Mark Twain
Unread 04-03-2014, 09:32
Rookie Year: 1997
Both are behind the lexan.
Unread 04-03-2014, 09:33
Both should be behind the lexan. In week one, some of the elements weren't on the truck resulting in the material being placed on top of the lexan rather than disassembling the upper portion of the driver wall. This was temporary and I believe it is still intended to be behind the lexan.
Greg McKaskle
