Go to Post Lesson learned: don't hide cables where drills can find them! - Richard Wallace [more]
Unread 04-03-2014, 15:57
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
Team Role: Leadership
Rookie Year: 2012
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Need a Machining service?
Hi all.
Our team has encountered a part we need machined - unfortunately, we don't have any machining capability (no machines whatsoever).
We're wondering if any team can recommend us an affordable machining service or if any team would be willing to machine a few very small parts for us (for a respective price, of course).
We're hoping to get these parts ASAP but of course machining isn't an "ASAP" process so we understand lead times vary.
In short: please let us know if you can recommend a machining service or if your team could help us.
This is actually for our FTC team rather than our FRC team - we need a standard tetrix rack (from a rack-and-pinion system) machined out of aluminum versus the nylon it is made from.
Thanks!
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 04-03-2014, 21:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Need a Machining service?
Don't have a machining recommendation, but consider this:
It is possible for you to make a mold of a nylon rack and then cast a duplicate in Aluminum. The hardest part is melting the aluminum.
Make a flexible silicone mold, cast a rack from wax, add the sprues and vent holes in wax, make a plaster mold, melt out the wax, pour in molten aluminum. Pewter is a reasonable alternative to Aluminum if you can't generate a lot of heat (melts as around 750F), but can accept a somewhat heavier and weaker material.
You can also make a 2-piece plaster mold if you prefer, but a bit more difficult to get good results.
Unread 04-03-2014, 21:58
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
There are a lot of artists and some school art departments that cast metal. If you have a mold they could help you out. We used our art department once.
KF6UZX
Unread 04-03-2014, 22:27
JVerstraete JVerstraete is offline
FRC #2771
JVerstraete is an unknown quantity at this point
ksafin,
If you still want to go the machining route you would most likely need to find a shop that can do Wire EDM machining. It will not be the cheapest route but, you might be able to find a sponsor out of it.
The other aspect of making the rack will be finding a file to make the rack to. I have not seen a file for the rack and pinion. Granted the last time I looked for one was back in November.
After a little bit of research I found a Wire EDM shop in you area that you might want to see if they can give you hand.
Here is there website. http://www.ligi.com/
I hope you find what you are looking for.
Unread 05-03-2014, 17:14
WIREDFTC's Avatar
WIREDFTC WIREDFTC is offline
More hot glue!
FTC #5035 (WIRED)
Team Role: Webmaster
WIREDFTC has a spectacular aura aboutWIREDFTC has a spectacular aura about
In the FTC Kit of Parts CAD files they have a model for the rack and pinion gear. It should work fine if you have PTC Creo 2.0, but when I imported it in to Autodesk Inventor Pro 2014 some of the geometry was odd on it.
