Go to Post Understand the problem before trying to apply bandaids. You might not even be putting the bandaids in the right spot. - Bryan Herbst [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 04-03-2014, 20:46
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Game Manual - Team UPDATE - 2014-03-04
http://frc-manual.usfirst.org/Updates/0#term 172
root
Game Manual
Section 2: The ARENA
Section 2.2.3: The GOALS
Note: In order to help minimize the chance of a BALL bouncing back out of a HIGH GOAL, we have modified the structure, as noted below in the update to Section 2.2.3.
Each ALLIANCE has two (2) HIGH GOALS located above their opponent’s ALLIANCE WALL. The HIGH GOALS are 11 ft. 6 in. wide and 3ft. 1 in. tall with the bottom edge of the opening located 6 ft. 10 ¾ in. above the carpet. The outside edge of each HIGH GOAL is semi-circular with a radius of 1 ft. 6 ½ in. The HIGH GOALS are separated from each other by a 1 ft. wide divider.
Horizontal pipes are installed behind the bottom of each HIGH GOAL to prevent SCORED BALLS from dropping directly on DRIVERS. These pipes are covered in ¼ in. clear polycarbonate sheet.
The perimeter of each HIGH GOAL is surrounded by Phillips Color Kinetics iColor Flex LMX LED light strings. The LEDs have several states that indicate GOAL status:
Section 3: The GAME
Section 3.1.2: MATCH Logistics
If the Head Ref determines that a BALL is becomes damaged or completely deflated, it will be replaced by a new replacement BALL of the same color will be delivered to one of the ALLIANCE’S HUMAN PLAYERS at the next safe opportunity. Once the new BALL enters the FIELD, the damaged BALL is invalidated, considered debris, and can no longer be used in MATCH play.
Section 3.2.6: ROBOT-ROBOT Interaction
Note: We have made a modification to G28 to indicate that the ROBOT committing the foul must have initiated the deliberate or damaging contact. We also clarified that the contact must be on or inside a vertical extension of the FRAME PERIMETER. The rule was already being interpreted this way with regards to the vertical extension, we just wanted to be clear.
G28
Initiating deliberate or damaging contact with an opponent ROBOT on or inside the vertical extension of its FRAME PERIMETER is not allowed.
Violation: TECHNICAL FOUL
High speed accidental collisions may occur during the MATCH and are expected. ROBOTS extend elements outside of the FRAME PERIMETER at their own risk; no penalties will be assigned for contact between two such extended elements.
A ROBOT with an element outside its FRAME PERIMETER may be penalized under this rule if it appears they are using that element to purposefully contact another ROBOT inside its FRAME PERIMETER. Regardless of intent, a ROBOT with an element outside its FRAME PERIMETER that causes damage to another ROBOT inside of its FRAME PERIMETER will be penalized, unless the actions of the damaged ROBOT are the catalyst for the damage.
Section 3.2.7: Human Actions
G31
Strategies employing TEAM member HUMAN PLAYER actions to inhibit ROBOTS are not allowed.
Violation: TECHNICAL FOUL.
G32
Strategies employing TEAM member HUMAN PLAYER actions to deflect opponents’ BALLS are not allowed.
G38
TEAM members HUMAN PLAYERS may not pass the BALL to a TEAM member HUMAN PLAYER in another HUMAN PLAYER AREA (passing the BALL within an ALLIANCE STATION or HUMAN PLAYER AREA is permitted).
Violation: FOUL
Note: We have made a modification to G40 as a compromise between a desire to mitigate the volume of G40 penalties incurred at Week 1 competitions and the fundamental objective of never allowing ROBOTS and Humans to occupy the same space at the same time during a MATCH. While this adjustment offers some reprieve for HUMAN PLAYERS who reach beyond the SAFETY ZONE during a MATCH, it maintains the SAFETY ZONE between the ROBOT and the HUMAN PLAYER when both are in the same area and stress that HUMAN PLAYERS prioritize safety and avoid the space unless necessary.
G40
During the MATCH, TEAMS may not extend any body part
in to a space defined by the Human Player Barrier Brackets, the SAFETY ZONE, and the GUARDRAIL that is either occupied by a ROBOT or adjacent to such a space occupied by a ROBOT
or,
beyond the GUARDRAIL at any time. into the SAFETY ZONE during the MATCH.
Figure 3-7
I can't wait for week 2 events now, should be a bit better.
Unread 04-03-2014, 20:49
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Game Manual - Team UPDATE - 2014-03-04
Goal fixes, G28 fixes, G40 fixes. I'm happy now.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 04-03-2014, 20:51
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Does 1/4" clear polycarbonate refer to thickness?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 04-03-2014, 20:50
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
Rookie Year: 2013
xXhunter47Xx will become famous soon enough
So if I'm understanding this correctly...
We can drive aggressively and damage caused to say, intakes that are extended are not a cause for penalty? If I drive into a bot with it's intake extended while playing hard defense and it tweaks their intake, that is no cause for a foul?
Unread 04-03-2014, 20:52
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
I added some formatting to make it easier to see the changes:
Game Manual
Section 3: The GAME
G28
G31
G32
G38
Violation: FOUL
G40
  1. in to a space defined by the Human Player Barrier Brackets, the SAFETY ZONE, and the GUARDRAIL that is either occupied by a ROBOT or adjacent to such a space occupied by a ROBOT
    or,
  2. beyond the GUARDRAIL at any time. into the SAFETY ZONE during the MATCH.
tanmaker
Posts: n/a
Correct, no foul, as long as it is not strategic. Teams should be aware that high speed contact can occur, and should design the robot, including appendages, appropriately.
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
When quoting the update you need to format it too, to make the changes obvious.
This update should fix a lot of the week 1 issues, lets hope they also fixed the behind the scenes FMS problems.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 04-03-2014, 20:55
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
All of this update is great!
Week 2 should go smoothly now.
Or at least acknowledged there was a problem...
Unread 04-03-2014, 20:57
Brandon_L Brandon_L is offline
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Still no better ball sizing standards, balls still take 10 years to return to play if they leave the field, and refs still have way too much on their plate.
I think they have a ways to go still, but its progress.
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 04-03-2014, 21:01
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
None of those really require rule changes, though. It would still be nice to see them addressed somehow, but this may not be the place to do it.
Does anyone else remember when TBA signatures actually worked?
Unread 04-03-2014, 21:51
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Indeed they did, much more than I expected them to be able to do in less than a week. I am very satisfied by the changes they made for Scorekeepers in Week 2, I am looking forward to Arkansas this week!
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 04-03-2014, 21:56
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Scorekeeper , ref and software changes would not be reflected in an update, that is not what they are for.
I would hope that a blog would be upcoming to help explain what other changes would have been made on these points.
Unread 04-03-2014, 22:17
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Exactly. Any hour now I am going to click on over to the home page and see a new post by Hallry linking to an FRC Blog that makes everything better.
Unread 04-03-2014, 22:28
I just realized the change to G40 does not really change anything, the only time you would cross the line is when you are tossing it to your robot, which would be adjacent to the station...
Or am I just reading this wrong?
  #15   Spotlight this post!
Unread 04-03-2014, 22:31
JosephC's Avatar
Rookie Year: 2011
Its my understanding that you can extend past the tape as long as there is no robot extending past the edge of the field. I could be completely wrong though.
Referee: 2015 - ?
