Go to Post I didn't say this! - Max Lobovsky [more]
Unread 05-03-2014, 01:43
gotgreen gotgreen is offline
AKA: Kevin Bowlin
FRC #0624
Rookie Year: 2007
gotgreen is an unknown quantity at this point
paper: grassHopper Hybrid Drive System
Thread created automatically to discuss a document in CD-Media.
grassHopper Hybrid Drive System by gotgreen
Unread 05-03-2014, 01:46
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain
AKA: Alexander Kaplan
FRC #1086 (Blue Cheese)
Rookie Year: 2010
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Re: paper: grassHopper Hybrid Drive System
This is pretty cool, but a couple of questions:
I am having issues wrapping my head around the hybrid shifter mechanism and the elastic tension, do you have a video of the mechanism shifting by any chance?
Also, what how heavy is the drive?
Unread 05-03-2014, 07:21
AKA: Kevin Bowlin
FRC #0624
Rookie Year: 2007
Apologies that it was not clear. The shifting bearing block is loose on the frame and has to be tensioned. Theraband is connected to the top of the shift plate where the pneumatic cylinder is attached and tensioned to the frame vertically. This seats the bearing block lower lip into the frame when the wheels are up. Also, when pivoting the blocks the chain is loose when up and tight when lowered. Ideally the pivot point should be moved out to reduce this issue. A small piece of theraband can be connected to the bottom of the block and tensioned to the frame. We are not using this. We just attached a small tensioner and it is working fine. The drivetrain complete w/o electronics is right around 30 pounds. I will double check the wieght when back at the build site.
Unread 08-03-2014, 00:33
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Awesome job making this available to everyone. I really like this drivetrain setup.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 16-10-2014, 10:41
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
I must admit a certain level of annoyance with this publication... we are working on a drivetrain almost identical to this one in function and theory that we thought was novel. We being Team 95, The Grasshoppers.
In seriousness though - it looks great!
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 17-10-2014, 00:17
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Your drawings show one lift plate and bearing block on each of the articulated axles but the photos show two. Did you find that the forces on the axle cause the two lift plates to "twist" relative to each other?
Unread 17-10-2014, 14:47
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Cool idea, as if Team 33's 2011 dual drive had a baby with a Nonadrive.
Unread 17-10-2014, 23:19
Abhishek R Abhishek R is offline
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Yes! That was the inspiration. It was an experiment our drivetrain mentor had in mind in the pre-season of 2014, but we just didn't have the time to try it out. He was confident that it would be successful, so we went ahead and tried it out during the build season as the drivetrain for our robot, and the results were amazing, we had all the benefits of a standard butterfly/nonadrive without any of the complexity - this was made with all COTS parts including VersaChassis and without any CAD, CNC, or anything like that - pretty much just a band saw and drill press. Our offseason changes made it much more efficient as well, and many people noticed a significant increase in agility going into competitions in the summer.
Game permitting, we're definitely looking into using it again!
2012 - 2015 : 624 CRyptonite
Team Website
Unread 18-10-2014, 08:51
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Very neat chassis. Did you have any trouble with it being pitchy in H mode?
Unread 18-10-2014, 20:58
Rookie Year: 2012
No, we didn't experience any noticeable torque on the plates. The system we used in the offseason held up through three full-size competitions (TRI, IRI, TRR, soon to be four with Remix) all with significant amounts of defense. We always had the ability to push others around when we wanted to and were able to break free from other teams attempting to pin us.
If by pitchy, you mean likelihood of falling over face first during sudden acceleration/braking - we came very close to tipping ourselves over, but it never actually happened (before someone brings it up, the one time we were tipped over was due to another robot intruding our perimeter and pushing us over from the side). I attribute this to our somewhat top heavy design (relative to other robots, our catapult's pivot point was much higher than others') and the short wheelbase of our 8-wheel square drivetrain. Nothing that wouldn't happen with a standard 8-wheel drive.
Thank you for the compliments!
Team Website
