Thread Tools |
Rating:
Display Modes |
Re: Were to store practice bot at regional?
(Emphasis mine)
An interesting subtlety I noticed on this search is that while "FABRICATED items consisting of one COTS electrical device (e.g. a motor or motor controller), connectors, and any materials used to secure and insulate those connectors" created before build season were permitted on the robot (or in the withholding) under R12, they were not exempt from being part of the withholding allowance under R17. |
Originally Posted by David Brinza:
In 2015, teams were required to bring their withholding allowance items into the pits during robot load-in. Going to the trailer or build site after load-in was not permitted. Robot inspectors would ask teams with a significant amount of fabricated items declared as "withhold allowance" to weigh them at the inspection station. Quote:
Team 1899 makes wood robots every year, I don't know if this is the team that you're referring.
4183 as well
1771 made wood robot from 2009 through 2012. Here is post I made at that time about wood frames.
I might be a little wary of Q416, where a bot for a Chairman's presentation was ruled to count toward the 45 lb allowance.
How much does the bot weigh? |
You will want to have your 45lbs selected and removed prior to going to competition. The rules state that you cannot work on the robot mechanical components outside of the pit or outside of the pit operating hours (no in-hotel work).
If you are bringing the entire robot, it would be best to leave it in the hotel. Thefts from parking lots are unfortunately, not uncommon. |
Store it at your school, your shop, your sponsor's facility, wherever you normally keep it. Don't bring it to a regional.
While you can use a used, unmodified, COTS part that was on an old robot, as a spare, you cannot store it on the robot until you need it. It's not a parts rack. A manufactured part, even if it's identical to one on your competition robot, can be a spare part, but it counts under your weight allowance and must be brought into the pits as a part, not as a part of a robot. Think about what you are asking. If every team brought a spare or practice robot to a competition, where would they put up to 60 extra robots? |
Dude, if what I read here is accurate, you need to understand that that's not ok. My team has a practice bot too, which we've used for drive practice and R&D. We will take our spare parts and improvements off of it and take them to competition, leaving the rest behind. 45 pounds only, excluding the bumpers, batteries, and COTS straight from the box. That is a generous rule and it's very clear.
#10
#11
If anything, the problem with the "practice bot in trailer" might be the addition of "static" to the rule. 2014: Quote:
#13
#15
