Thread Tools |
Rating:
Display Modes |
Re: Were to store practice bot at regional?
Yeah, it is a whole lot of work. |
Adam, feel free to correct my interpretation... |
I understood Adam's question the same way you did. My answer is that the practice robot is a FABRICATED ITEM, and that team access to such items is limited to 45 lb during an event as required by R18.
In my opinion, the addition of 'access to' and 'static' in this year's rules makes it pretty clear that bringing your entire practice robot to the parking lot and picking and choosing your 45 pounds based on what you need (or what breaks), is illegal. |
The rule says: At an Event, Teams may have access to a static set of FABRICATED ITEMS that shall not exceed 45 lbs. Emphasis mine. If you can go to your trailer and get a part from a practice bot, that's access. If you have access, or potential access, to more than 45lbs worth of parts you are in violation of the rule. |
Our 2nd event is 2-3 miles away from our working facility. Does that mean every single part in our facility counts to the 45 lb limit, since we have access to it during the competition? |
Do all of your competitors have the same ability? Otherwise it gives you an exceedingly unfair advantage. This is also why the rules prohibit working on any robot parts outside of the pit area. |
I guess the questions is what defines the event? If it's in the building it counts. Does in the parking lot count? how about 3 blocks away? 4 miles? 250 miles?
If we sent someone to our shop to make a part for our team or another team that is against the rules as well? The definition is vague and causes problems. |
#10
A rule of thumb here might be: Behave as if you had traveled to the Regional from a thousand miles away. This is where gracious professionalism comes in to play. |
#11
Of course, I've always felt the 45 lbs is upgrade parts. 1 to 1 replacement parts shouldn't count since they are functionally equivalent to parts you bagged. (This isn't how the rule is, it's just how I think it should be) |
#12
I'm saying that you will be under the honor system that you've pre-selected your 45lbs of withholding and won't go to your shop to take advantage of resources and spare parts that other teams don't have access to. |
#13
Spare parts (including fabricated identicals) STILL count against your 45 pound allowance. If you have two robot arms that are identical, one of which is on the bagged robot and another you bring in, the arm you brought in counts against your 45 pounds. If you bring in (or have access to out in your trailer) more than 45 pounds of spare parts (not including things like COTS, raw materials, etc.), you are absolutely in violation of the witholding allowance. Otherwise, there would be no reason to have the witholding allowance rule in the first place. You don't get to have a whole practice robot in your trailer to farm parts from. You have brought ~120 pounds to the event. Even if you only select 45 pounds from it. You still brought your whole practice robot to the competition. You are in violation. Pick the parts that are most likely to break and bring spares of those. Yes, I know many teams violate the rules. So stop it. |
#14
So, as long as my parts are preselected (I provide a list and proof that the parts are under 45 lbs) I should be set? Furthermore, what defines a robot? I can bring in a spare sidecar, PD board, CRIO, and radio and that's not a robot... If they happen to all be zip tied to a piece of lexan for easy carrying? Is that now a robot? I admit, I'm just being difficult. I have every intention of following the spirit of the rule (don't bring in more than 45 lbs of custom made upgrade parts per event) but I don't see myself locking up parts in my shop to comply with the letter of the rule. |
#15
At what point do you say a team doesn't have potential access? How is it unfair that our facility happens to be within walking/subway distance of the venue? I'm just pointing out a flaw in the wording of this rule. |
