pic: Wheel progression
Re: pic: Wheel progression
They certainly wear, but from what I've seen the grip is worth it. |
And you really can't beat the price. Even if we have to replace them six times they'll be cheaper than our wheels last year.
I'll get a picture of our drivetrain wheels, but we are seeing similar wear on the tire version of the diamond tread on both our practice and competition bot. The grip these suckers had when they weren't worn (and they still have decent grip) was great, but we're going to drive the practice bot a little bit more aggressively than before to see if the wear on the wheel is affecting its performance. It'll be a pain to switch the treads on the wheels, but if we find we're getting significantly better performance using the blue nitrile or SBR tread we used last year, we're ready to do that switch.
With this kind o fwear happening quickly on the diamond tread pattern, why not switch to the W-tread? It' has a higher CoF and is ever so slightly cheaper. The advantage of the VersaWheelDT was supposed to be their resistance to tread wear, but if that's not actually the case, I don't see why you'd use them* over the regular VersaWheels.
*If you're using the 3.25" variant, obviously, it's your only choice. |
We saw similar wear on our wheels... we have a 6WD wide bot (not sure if our center is dropped, I don't believe so).
The center wheels look pretty good, but the outer wheels were about as worn as the 2nd wheel from the left. This was after 4 or 5 hours driving in our shop and ~10 matches at our district event. |
These wheels grip more based on material than the really shallow tread pattern, hence my question. -Aren |
I can't see any reason you couldn't do this. -Aren |
#11
I was going to say something that one of our mentors said Aren said but looks like Aren beat me to it d:
#12
Would the wear nullify the whole premise of the drop center regardless of wheel material?
