Go to Post Don't let my students know I skimmed that blog and didn't read it thoroughly. - rlance [more]
Unread 07-03-2014, 20:50
Tedi Tedi is offline
FRC #4343
Tedi is an unknown quantity at this point
Can isTimedOut() be used in a command group?
Hey guys,
So I was wondering if in the constructor of a command group (where addParallel and addSequential are added), can I also add setTimeout(x); and then check within the same command group if it has timed out? I am asking because I am unsure if setting a timeout inside a command group actually works or if it's only for commands.
Example:
Code:
public class cmdg extends CommandGroup {
    boolean A = false;
    public cmdg() {
        setTimeout(x);
        addSequential(command_here, x);
        if (isTimedOut()) {
            A = false;
        } else {
            A = true;
        if (A) {
            //stuff here
        } else {
            //stuff here
Thanks,
Tedi
Unread 07-03-2014, 22:20
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Since CommandGroup extends Command, you can override isFinished. However CommandGroup isFinished implements a few checks, so you should make your isFinished be super.isFinished() || isTimedout() or you'll break the CommandGroup.
Unread 09-03-2014, 15:27
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: Can isTimedOut() be used in a command group?
No. The constructor only runs once at robot initialization, so none of the commands should be timed out.
Unread 14-03-2014, 15:51
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
To reiterate this....
The only way to use isTimedOut is to first use seTimeOut within the command, or command group.
If you use the 2 paramter constructor to set the timeout value, this is never seen by the command, instead I believe it is passed to the scheduler to be killed.
So isTimedOut will always return false, unless you exlicitly set the timeout within the command itself.
Is that clear?
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
