Go to Post Is all your information based on hearsay and miscellaneous posts by other people that don't know what they are talking about? - dlavery [more]
Unread 09-03-2014, 16:19
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Can one SPST limit switch drive both Jaguars in a 2-motor gearbox?
Overview...
Can anyone give us some insights into the Jag Limit Switch input circuits?
CAN we drive two Jag Limit Switch inputs, with a single SPST switch?
Problem description:
We're using a pair of motors on one gearbox for a payload device, and need to add a limit switch to the PAIR of Jags driving them. We definitely do NOT wish to use two separate limit switches for each direction. (No space, plus failure mode concerns...)
In essence, we wish to design a proper "Ganged Limit Switch" for a pair of Jags, to turn them BOTH off at the same time local to the Jags from ONE (preferably SPST) limit switch. BUT we don't know how the Jags' limit switch circuits are implemented internally, and whether we can cross connect them without damage.
Can anyone give us some insight as to how the Jag's limit switch circuit is implemented internally? (We don't wish to risk Jag damage with limit switch input ganging experiments...)
IOW... What's the right way to approach this? Can we use diode blocks on whichever are their "hot pins", and use a single SPST swtich to drive both jags, or will we need to electrically isolate them from each other with (for example) DPST limit switches, a DPST relay contact set, opto isolators, etc? (I speak electronics... Feel free to talk about circuits and diagrams...)
Thanks.
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 09-03-2014, 16:23
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Can one SPST limit switch drive both Jaguars in a 2-motor gearbox?
Is there any reason you can't wire the switch to the DSC and implement it in software?
If you have to use the Jaguar, the input wants between 2 and 5 volts for high and has a 10 kΩ pull up resistor and a 64μs response time. Here's the schematic:
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 09-03-2014, 16:27
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
We have done it successfully in the past with 2 motors powering one arm. Just one thing to note, make sure the wires are the right orientation on the Jaguar itself. Take note of the way it is plugged into one Jaguar and make sure it is the same on the other. As long as they are the proper orientation, it should work just fine
I'm right 90% of the time, so why worry about the other 3%?
