Go to Post GP is an ideal to live by, but not a tool to judge with. - Rich Kressly [more]
Unread 09-03-2014, 19:54
ILikePizza555's Avatar
ILikePizza555 ILikePizza555 is offline
AKA: Isaac Avram
FRC #2761 (CN Ironhorse)
Rookie Year: 2012
ILikePizza555 is an unknown quantity at this point
Command-Based Programming Patterns
Hey all,
So we used the Simple Robot Template this year for the programming of our robot. It works, but it's not the best way to code, especially when your expecting a few new members on the programming team. I've tried to port our code to use the Command Pattern, but I'm not sure how to structure it.
So, I've come for some help. How do you guys structure your command-based programs?
PONIES ARE STOOPID MAGIK -Heavy
Unread 09-03-2014, 20:50
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: Command-Based Programming Patterns
WPI has a very nice overview and tutorial on using the command based framework at: https://wpilib.screenstepslive.com/s/3120/m/7952
It is a very powerful framework, but expect it to take some time to wrap your head around it. It might be a challenge to switch mid-season.
Unread 09-03-2014, 21:23
AKA: Isaac Avram
Rookie Year: 2012
Looking at the other frameworks I have used before (not robotics related). It's not quite that powerful, in my option.
Also, I have looked at those docs. The "Converting a Simple Autonomous program to a Command based autonomous program" seems new, so I'll have a look at that. The things is though, I'm looking for advice on general program structure, not on making commands, command groups, and subsystems.
Also, the season is pretty much over for us.
Unread 10-03-2014, 01:44
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
If you're mainly interested in the structure of the program, then check out our (unfinished) code for this year. The structure is all there, even though it's only about 85% done.
I'm actually kind of proud of it, since last year was pretty disorganized.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 10-03-2014, 18:36
AKA: Isaac Avram
Rookie Year: 2012
Neat. Thanks for that. I'll have a look over it and see what I can get from it.
