Go to Post Remember, the song is FIRST and the competition. We are the group. We dance to FIRST, we move because of it. - Joe Matt [more]
Unread 10-03-2014, 10:57
thmeans06 thmeans06 is offline
Drive Coach, IT Support, Mentor
FRC #0066
thmeans06 is an unknown quantity at this point
Weird Radio Issue When Deploying
Hello everyone,
This year, we encountered a very weird issue and were wondering if the radio we have could be bad.
We were using our radio, tethered, and were deploying code as we have all build season. Everything has been going fine all season until the other day. Out of the blue, while deploying code, it hangs up at "Sending File Image.Suite". It never moves after that point. It does, however, still see the robot and Driver-Station is able to control the robot.
The troubleshooting steps we took:
  • Different ethernet cables
    Verified are IP Addresses
    Different Radio Ports
    Verified Radio was in the Correct Mode
    Rebooted cRio
    Rebooted Computer
    Reverted to Old Code
    Re-imaged Radio
    Firmware Update to radio
    Used FRC Bridge Config Utility to Program Radio
    Programed the Radio Manually
    Everything Possible Related to Network Settings on the PC.
Nothing seems to help unless we plug in directly to the cRio; we are able to complete deployment perfectly. If we plug in a different radio, deployment completes successfully as well.
Anyone else seen or heard of this issue? Should we contact D-Link?
Unread 12-03-2014, 14:10
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Weird Radio Issue When Deploying
Can you ftp to the robot with the "bad" radio? Do you have a firewall? It could be blocking netbeans on one network but not on the others.
