Go to Post You must have a base on which to stand. Knowledge is the base that wisdom stands on. - Steve W [more]
Thread Tools Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
Unread 10-03-2014, 12:23
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
exploding plastic storage tanks
This past week at the Lake Superior regional we had one of the plastic air tanks from Clippard explode on the field, sending pieces all the way up into the stands (at LSR the stands start about 10 ft above the field, with plenty of space between them and the field), and I heard there was a tank that blew in week 1 as well.
At LSR, we believe the failure was caused by damage to the tank, not a manufacturing defect (like a void in the plastic wall). The team used hose clamps to attach the tank to their robot - the screws from the clamps bit into the sides of the tank, and when reassembled the tank was slightly deformed from being squeezed by the clamps. As far as we can tell, the initial fracture point was right under the clamp, near the screw. Further, the tanks were mounted in a very exposed position, and took some hits from other robots.
I want to strongly caution teams to mount these tanks properly (with the provided plastic clips or through some other means that holds them securely without applying undue pressure on the sides of the tanks) and to protect them inside the frame perimeter. The tanks were designed for a much gentler use than we're putting them through (mounting to a static mechanism that doesn't take impacts or damage, and doesn't need firm mounting to hold the tanks in place), and rough handling will eventually lead to failure!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 10-03-2014, 12:27
scaryone's Avatar
scaryone scaryone is offline
FRC #0058 (The Riot Crew)
Team Role: Coach
Rookie Year: 2007
scaryone will become famous soon enough
Re: exploding plastic storage tanks
Maybe wrapping the tank with a sleeve to catch pieces if they do fail would work?
Unread 10-03-2014, 12:32
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Our team uses velcro
Unread 10-03-2014, 12:37
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
I would definitely second the mention of being careful with your mounting. Any harsh mounting (hose clamps) that deforms the tank or otherwise marks it is changing the mechanics of the system rather dramatically.
The polymer used to make these tanks seems fairly brittle, that combined with the high stresses involved can lead to failure with little to no warning.
Makes me comforted to know that on Neutrino our air tanks are placed in our 3x3 6061 drive tubes so in the event of a failure it should all be contained.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 10-03-2014, 12:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Would a "sleeve" contain the shrapnel, or direct it (at higher velocity) in two directions?
We have several old metal tanks, we'll continue to use them.
Unread 10-03-2014, 12:52
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
A properly designed containment sleeve would contain shrapnel, but a poorly designed one could certainly direct shrapnel out either end at a high velocity.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 10-03-2014, 12:56
FRC3883FRC's Avatar
FRC3883FRC FRC3883FRC is offline
FRC #3883 (Data Bits)
Rookie Year: 2011
FRC3883FRC has a spectacular aura aboutFRC3883FRC has a spectacular aura aboutFRC3883FRC has a spectacular aura about
Our team had our tanks on our intake a very vulnerable position. We were highly highly HIGHLY recommended by the inspectors (almost to the point of not passing) to cover our tanks. We simply added bumper material over both of the tanks. They still fit right in the same c claps they some with and they dont look all that bad. A couple zip ties and the bumper fabric and we were good to go. You can see in the video that our robot has two red tubes at the top of the intake and around 9 seconds in you can see why they highly recommended covering them up.
Here is the video.
http://www.youtube.com/watch?v=nvAFL...u8USGMhWY2qgkw
If you are using these tanks make some covers or make sure they are in a very safe location.
Team 3883, The DATA BITS!
!!!MN State Champs 2012!!!
Unread 10-03-2014, 13:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Here is the video.
Do you think that you are actually providing any meaningful protection by wrapping the tanks with bumper fabric and zip ties?
Unread 10-03-2014, 13:09
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
A spandex sleeve (or even bumper material...) over each tank would be an elegant and easy way to safeguard folks from flying debris, and the porous nature of the fabric would prevent the air pressure from 'exploding' the sleeve.
Hey ANDYMARK! Are you listening?
Unread 10-03-2014, 13:16
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
In one case, the problem was a student over-tightening a fitting to the plastic threads. In another case, we believe that Loctite was used on the fitting threads.
A good point. A good many liquid pipe thread sealers are not intended for plastic pipe. Only use them on the material listed on the can.
Unread 10-03-2014, 13:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
No, no it wouldn't. See other posts in this thread about shrapnel puncturing ball covers without issue.
I think I posted something similar last year... but biaxial kevlar sleeve or similar would be required to provide even modest protection. Multiple layers would be required IMO, and a good way to keep the ends of the sleeve closed.
Edit: what velocity air flow is needed to exert a significant pressure on a fabric? Said fabric doesn't need to be air-tight to sustain significant loading in the event of a storage tank's catastrophic failure. Not to mention cutting and tearing resistance to the sharp tank fragments.
Unread 10-03-2014, 13:26
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
this makes me want to test one to failure just to see that it takes to bust em
Unread 10-03-2014, 13:29
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Don't do it. It's seriously scary, especially when you're 4ft away from it. I couldn't hear from the ear facing the tank for about 15 minutes, and it hurt for the rest of the weekend. The shrapnel went flying into a pit about 30 ft. away, and killed our driver station computer.
Don't do it.
So it seems that this has happened at least four(?) times in the last two years. If FIRST was serious about safety these would be outlawed.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 10-03-2014, 13:45
Tom Line's Avatar
Rookie Year: 1999
Don't do it.
I STRONGLY disagree that the only avenue of improving the potential safety issues around plastic pneumatics tanks is outlawing them. I would much rather see a numbers-driven problem solving method applied.
However, I can see vendors stepping away from supplying a 'safety' item like a sleeve since it becomes a question of liability if someone gets injured.
  #15   Spotlight this post!
Unread 10-03-2014, 13:53
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Whether a sleeve is an effective solution or not wrapping a piece of bumper fabric around a tank in a bad location and deeming it safe without any proper testing is ignorant.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
