Re: exploding plastic storage tanks
As said earlier in this thread, tanks hose clamped down passed inspection! There was a team at GTRE this weekend with the black Clippard tanks (which are better in terms of not needing fittings) on the bottom of their intake arms which extended beyond frame perimeter and were the first point of contact in high speed crashes with other robots! They passed inspection too. The black tanks have their place in FRC if mounted correctly in the appropriate location, but the white tanks need to go. They've a hazard to everyone within 30 ft. of them. When teams (including my own) use them incorrectly, it's just a recipe for injury, and it's only a matter of time before someone seriously gets injured. I've been hit by moving robots, smacked by robot arms, and had my fingers pinched in more robot mechanisms than I care to count, but none of these are even close to the potential danger of these tanks. |
![]() That seems very fun [and dangerous]. Do not try this at home! I think the best sleeve would be a kit of the tank and sleeve so the strongest parts of the tank are the places uncovered. The rest should be contained. We are using mostly metal tanks, but we might (I can't properly recollect) have 2 plastic tanks! What are these tanks made of? "Polymer" is quite wide of a material definition. It feels like PVC, but I doubt PVC is that strong! |
Rupturing tanks at 120 psi is not fun.. not in the slightest. While there have been (luckily) no serious injuries from exploding tanks, it can leave you quite shaken. The sound is nothing to sneeze at either, at GTRW many students had momentary hearing loss and ear pain that lasted into the next day just from being in close proximity of it going off, and this was in a large open area. |
Polypropylene, not PVC.
From the FIRST blog last year: Over the weekend, it was brought to our attention that a failure of the white polypropylene air tank, donated by Clippard (Clippard PN: AVT-PP-41, AndyMark PN: am-2007, FIRST Choice PN: fc13-100), had occurred. |
As are Pneuaire air tanks. |
Additionally, plastic becomes brittle with age.
It is why infant seats for cars have an expiration date. We use Consequence vs. Likelihood in our 5x5 risk matrices. All components that see 125 psi should be rated for 125 psi or above. There is a factor of safety already built into their rating. Make sure the PRV is calibrated properly. Is the gage calibrated properly? The hazard is from the shrapnel created. The cause can be tank rupture due to: brittle plastic, over pressurization (not properly calibrated PRV), manufacturing flaw, design flaw, workmanship issues (assembly), damage from improper handling, mistreatment, environmental factors (temp, humidity, etc.), etc. |
I can't help but wonder, though, if even a bumper-fabric sleeve would eat a significant amount of the kinetic energy, when applied at the failure point (thereby partially inhibiting the extreme acceleration of the plastic shrapnel). Agreed that kevlar would be better, though. |
1310 had an air tank explode in their pit and the pieces went right through the FRC Ball puncturing 2 layers of fabric and rubber without slowing it down. I doubt the bumper fabric would be able to contain it. |
#10
------ We're actually running two of the black clippard tanks on our robot now, and haven't had any issues. Our mounting is fairly simple, we ran a strip of adhesive backed rubber down one of our metal structural members and then ziptied the tank to the member. The rubber does a pretty good job of holding the tank snug while also allowing it to have a bit of cushioning. |
#11
The ball was punctured by pieces already moving at considerable speeds, but the fabric would be able stop them before they get moving.
#12
I have witnessed this in person twice (both times in 2013) and thankfully nobody was hurt either time. But they probably could have been.
In one case, the problem was a student over-tightening a fitting to the plastic threads. In another case, we believe that Loctite was used on the fitting threads. Last year I proposed a mandatory sleeve in this post. I think it would be a cheap, easy, and effective harm reduction measure (though it would certainly need to be well-tested)...and it would let teams color their air tanks however they see fit ![]() |
#13
One of 1310's tanks blew at GTR west. One of the mentors was tightening a fitting into the tank with the tank inflated to 120 psi try to eliminate a leak. The tank exploded in the mentors hands, (thankfully no injury's) and destroyed the laptop that was below the tank, aswell as popping one of their balls. The shrapnel was sent flying all the way to the roof of the fieldhouse, and was quite a shock to those at the event.
PLEASE ensure that if you are using the tanks, that you do not over tighten the fittings. I highly recommend pipe dope (thread sealant paste) for the plastic tanks. It allows you to tighten the fittings less while maintaining a good seal. something like this http://www.henkelna.com/product-sear...=8797874651137 The tanks are both a blessing and a curse, please treat them with care, as both inexperienced students and "experienced" mentors have fallen victim to these tanks. Last edited by donkehote : 10-03-2014 at 13:18. |
#14
That said, air pressure is nothing to play around with. As we have seen an many posts about exploding tanks this year, safety MUST be taken when using pneumatics. Many people are trying to find a way around the Safety Rules by saying they are not rules. In FIRST we do not want to see people injured. We want FIRST to be a positive experience for everyone. Losing a part of your body or an eye is NOT a positive experience. I know, it won't happen to you, but we don't want to take a chance. Some rules are maybe a bit overboard but I would rather have that than have someone hurt because of lack of rules. |
#15
as a person whom has had PVC explode in my hands I would like to testify that you won't necessarily get pvc shrapnel damage to your body
