Go to Post I was not looking at this as a backdoor to asking Brandon to do it (when I have impossible/unreasonable tasks I want done, I ask him straight out ;-) - Joe Johnson [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 01:01
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
I NEED AN ANSWER!!! EVERYONE READ!
Posted by Rob DeCotiis at 2/17/2001 9:18 AM EST
Student on team #504, RoBUCtics, from Red Bank Regional High School and Jesel.
Can we use an angle bracket that's 4"?? would that be considered a joining plate for an extrusion or would it fall under steel angle in the additional hardware list???
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: I NEED AN ANSWER!!! EVERYONE READ!
Posted by Elgin C at 2/17/2001 10:56 AM EST
Engineer on team #237, Sie-H20-Bots, from Watertown High School / NVCC.
In Reply to: I NEED AN ANSWER!!! EVERYONE READ!
Posted by Rob DeCotiis on 2/17/2001 9:18 AM EST:
: Can we use an angle bracket that's 4"?? would that be considered a joining plate for an extrusion or would it fall under steel angle in the additional hardware list???
There are limits on the size of angle you can use. It is somewhere in the Adittional Hardware list. Hope that helps.
#0047 (ChiefDelphi)
angles... only up to 2" x 2"
Posted by Ken Leung at 2/17/2001 12:42 PM EST
Student on team #192, Gunn Robotics Team, from Henry M. Gunn Senior High School.
If you did not physically join the plates together to form angle bracket (like welding them together), then yes, it falls under steel angle in the additional hardware list.
But if you are using 1/4" thick steel and bend it into angle bracket, that that will fall under steel plate (any amount).
Please try to make sure you don't actually use the 4" x 4" steel angle bracket and claim them as manufactured from steel plates if you actually didn't.
[IMG] code is Off
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
read and write command rosebud Programming 3 26-03-2003 19:44
Read the Rules! Gadget470 General Forum 13 09-01-2003 13:58
Marking forums read David Kelly CD Forum Support 6 15-05-2002 14:50
'read' posts that arent read mike o'leary CD Forum Support 4 10-06-2001 11:29
