Go to Post Rule 1. Never take Dave's hint's seriously. Rule 2. Watergame. - AndyB [more]
Unread 10-03-2014, 18:04
35Billy42 35Billy42 is offline
FRC #3542
35Billy42 is an unknown quantity at this point
Camera Programming
Hey everyone! I'm trying to program a D-link DCS-930L Network Camera. Due to the Cloud Settings on it, I can't get it to connect to my robot. Is there anyway I can get past the Cloud Settings?
Unread 10-03-2014, 18:20
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Camera Programming
How are you trying to access the camera?
Are you using the WPI Libraries, or some other method?
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 10-03-2014, 18:34
FRC #3542
I haven't even gotten that far yet. I'm trying to setup the camera so I can access it through the WPI robotics library. I believe I need to enter the IP address still.
Unread 10-03-2014, 20:01
If it isn't an Axis, WPILib will not work on it. You will have better luck using a web browser to log into the camera and using the web browser as your dashboard or a component in your dashboard.
Greg McKaskle
Unread 28-03-2014, 07:25
DrTulof DrTulof is offline
Rookie Year: 2014
DrTulof is an unknown quantity at this point
First, we should define the protocols. Because Panasonic has its own and D-Link has another. Moreover, we should pay additional attention to the data itself - MJPEG, MPEG2, MPEG4 ....
Unread 28-03-2014, 14:13
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
I am pretty sure there is a way to give the MJPEG stream URL into WPILib instead of just the IP address. Otherwise, you may also use OpenCV or RoboRealm!
After looking at some of our robot code, we just supply the address, "10.11.65.11". I am pretty sure you could find the AxisCamera object and modify it to connect to the right address of the camera!
Unread 28-03-2014, 22:01
The camera runs a web service. If you don't type in the right URL, it won't work. The WPILib camera libraries were built around the commands for Axis. It would actually be a good challenge for you to try and update them to support a new camera, but you would need to follow the documentation quite closely.
Greg McKaskle
Unread 28-03-2014, 23:03
AKA: null
Rookie Year: 2012
It really depends on the internal workings of the WPILib. If it uses a standard MJPEG stream, you're golden. If it uses a JPEG image downloaded from the AXIS camera (standard: "[IP]/jpg/image.jpg", you are probably golden, otherwise, you'd need to create your own object. In this case, try a simple port of the OpenCV CvCapture because that will give a good standing point! It supports MJPG, and dozens of other protocols/file formats!
Unread 28-03-2014, 23:21
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
The AxisCamera class doesn't just get images from the camera. It's able to change exposure, brightness and other settings on the fly.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 28-03-2014, 23:32
AKA: null
Rookie Year: 2012
I guess. I haven't been thoroughly through the code. However, you just enlightened me! . Maybe I could port that to OpenCV so it can change those variables too!
You're brilliant! Thanks!
Unread 29-03-2014, 13:26
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
Rookie Year: 2013
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
OpenCV can already configure those variables with VideoCapture::set
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 29-03-2014, 17:12
AKA: null
Rookie Year: 2012
I didn't know that! However, I use CvCapture, not VideoCapture! I don't know if it'll work for me! Anyways, my program is robust enough to resist the camera changing it's settings automatically! In fact, I'd prefer the camera to auto adjust because it seems like as long as it stays in a certain limit. all izz well and my program should be able to work at a reasonable accuracy!
Unread 31-03-2014, 17:15
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
Rookie Year: 2012
sparkytwd will become famous soon enough
If you're using a V4L based camera, you can also change camera settings during active capture. #3574 does that to switch our front facing camera out of autonomous mode to something more usable by a human.
