Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
Unread 10-03-2014, 18:18
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Hot Goal Timing Issues
This weekend at the Central Valley Regional we noticed an issue with the synchronization of timing between the field management system enabling robots and the triggering of the hot goal lights and targets.
We found that robots were being enabled up to a second before the lights and vision targets indicating the hot goal turned on. This seemed to be a simple time shift as robots would stop moving before the lights turned off and the second hot goal lights would activate exactly 5 seconds after the first hot goal lights turned on. This creates 2 issues:
1) Given humans score the hot goal by way of the field lights and not the field timer, teams had approximately 6 seconds to score in the first hot goal and 4 seconds to score in the second hot goal.
2) Teams had to wait 1 second in auto mode to sense the hot goal. With multiple moving robots and shot being fired, the challenge becomes much different than initially expected.
Over the course of an entire match one second would probably not be a huge deal but given the 5 second scoring window for the hot goal, this bug equates to a 15-20% decrease in available scoring time. Many teams have designed their robot to score balls in the hot goal over a 5 second period. In some matches they are being given less than 4 seconds.
Here are some illustrated examples of this happening. These videos have a timer that starts in the first frame that I can see robot motion, which is the best indicator I have of robots being enabled. There could be more time of "enabled" on top of this as robots may not start moving at exactly t=0.
CVR Qualification Match 2: http://www.youtube.com/watch?v=mgI_PkgsuXA
In this match, the second hot goal is only active for 3.9 seconds. The first hot goal is not indicated until 1.1 seconds after robots are enabled. The second hot goal is activated at 6.1 seconds. Robots are disabled when the overlay timer shows 10.0 (you can see a ball in 254's robot start to move towards the shooter then fall as the single acting solenoid outputs are disabled.)
CVR Qualification Match 83: http://www.youtube.com/watch?v=RXKHpcc6ZOE
In this match, there is a .7 second delay from robots starting to move until the hot goals activate
CVR Qualification Match 11: http://www.youtube.com/watch?v=rycIqPJpbz4
In this match, there is a .6 second delay from robots starting to move until the hot goals activate
CVR Qualification Match 32: http://www.youtube.com/watch?v=9Q3KVlqbwvc
Since the robots are not visible in this video, I have synced the overlay timer to read 1.0 when the match timer on the field changes from 10 to 9. There seems to be about 1.2 seconds of delay from robots on to hot goal on, and a 3.8 second long second hot goal.
As an additional data point, we observed that the scorekeeper seemed to be enabling robots from the PC interface, not the blue hardware control box.
Of the issues listed above, it seems point 2 has a very simple fix. In 2008, drivers were not allowed to touch their controls once the “ball randomizer” had determined ball position and field crews could place them. The first hot goal could work in a similar fashion and be lit before the match starts.
Has anyone else seen issues like this? It would be nice to have these issues fixed for future events!
Thank you,
Team 254 Mentors and Students
Unread 10-03-2014, 18:31
JTEarley JTEarley is offline
AKA: JT E.
FRC #0624 (CRyptonite)
Team Role: Leadership
Rookie Year: 2011
JTEarley is an unknown quantity at this point
Re: Hot Goal Timing Issues
This happened at Alamo as well, but sometimes the delay was much worse. In finals match 2, the first hot goal lit up and never switched.
The delay has caused our 2 ball, 2 hot goal auto to be a 2 ball, potentially 2 hot goal auto. Due to our setup, our bot sees the right vision target and decides which goal to shoot at first. The delay makes it always think that the right goal is hot first so it starts moving before a hot goal has actually lit up. So we just have to hope that the right goal is hit first.
I hope this can eventually be fixed
Unread 10-03-2014, 18:33
billylo's Avatar
billylo billylo is offline
FRC #0610 (Coyotes)
Rookie Year: 2012
billylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant future
We noticed similar behavior at GTRW.
#go610
Unread 10-03-2014, 18:38
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
This is EXACTLY why we asked the following question to the Q/A system. Appearently the answer given is not actually representative of how the system operates.
Q66
Q.Exactly when in the match does the first "Hot goal" indicator flip so that it is visible? Befor auto, at the
beginning of auto, or some short period of time after the start of auto?
A.Per Team Update 2014-01-10 both VISION TARGETS will be positioned such that the the reflective
material faces the FIELD prior to the MATCH. The signal to flip one VISION TARGET to hide the reflective
material will be sent at the start of AUTO.
Here is what the 2014-01-10 Team Updates states:
The VISION TARGETS
There are four (4) VISION TARGETS on each end of the FIELD: two (2) dynamic VISION TARGETS and two (2) static VISION TARGETS. There is one (1) dynamic VISION TARGET located above each LOW GOAL. Each dynamic VISION TARGET is located behind the polycarbonate panel on the ALLIANCE WALL. The dynamic VISION TARGET is horizontal and begins 5 ft. 8 in. above the FIELD carpet, is centered over the LOW GOAL, and consists of a panel with one (1) 4 in. wide, 1 ft. 11 ˝ in. long strip of retro-reflective material (3M 8830 Silver Marking Film) adhered horizontally along the length of the panel with a 2 in. black ABS plastic border surrounding the retro-reflective material. The dynamic VISION TARGET is actuated to show the retro-reflective material when its corresponding HIGH and LOW GOAL are HOT. It will rotate to hide the retro-reflective material (pointing it upwards) when its corresponding HIGH and LOW GOAL are not HOT. Both of these conditions are shown in Figure 2-9.
Before the MATCH starts and throughout TELEOP, both dynamic VISION TARGETS are positioned such that the the reflective material faces the FIELD.
The static VISION TARGET is mounted such that half is behind the polycarbonate sheet above the LOW GOAL and half is behind the acrylic panel of the PLAYER STATION. It uses vertical reflectors which are located above the inside edge of the LOW GOAL. The vertical reflector consists of a 4 in. wide, 2 ft. 8 in. tall stripe of retro-reflective material bordered by 2 in. wide black gaffers tape on the left and right sides. The vertical reflectors begin 3 ft. 1 ˝ in. above the FIELD carpet.
The blue underlined text is where the update was made.
Notice that no where does it say EXACTLY WHEN the targets flip.
We were right there with you Tom, we saw the same issues in our matches as well.
I hope a post from me following Sac/Davis this weekend will have better news to report!
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 10-03-2014, 18:41
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Our team abandoned HOT goal detection a few matches into our regional and felt it was more efficient to make up the lost 5 points in TeleOp. We have now turned our focus to a two-ball auto.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 10-03-2014, 18:44
Yipyapper's Avatar
Yipyapper Yipyapper is offline
St. Louis Or Bust
AKA: Aaron Gordon
FRC #0781 (Kinetic Knights)
Yipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond reputeYipyapper has a reputation beyond repute
It's a real killer if the hot goal doesn't light up as soon as the match starts or goes at a variable time and you're detecting the saturation of the goal to determine if it's hot or not.
Thankfully this wasn't an issue at GTRE, but nevertheless I hope it isn't an issue for our team at future events (and others if they use the saturation values of the hot goal--do any of you do this instead of using the retroreflective tape?).
Programmer/Driver for Team 781 -- The Kinetic Knights 2010-2014. 2011 World Finalists!
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
In the 22 matches we played and the 22+ matches I watched while in queue, we saw a hot goal problem twice. The first time, one side of the hot goal remained on the entire auto period. A few seconds after teleop started, the match stopped, and was reset. Our drive team was never told why. The second time the exact same thing happened. I don't know if it's a coincidence or not, but in our three full match replays, the hot goal side changed at least once, but I don't know if a match restart has the ability to switch the hot goal side.
After this match, I watched the timer, and every other time, the hot goal switched within .5 seconds of 5 seconds on the timer.
Another observation I had was that the timer, lights, sound effects, and robot state weren't as lined up as they were last year. In a few matches, our robot was disabled before the buzzer and the lights went off. In one match, I loaded the shooter right as the buzzer stopped.
I don't think it's a problem with the light controller because they were able to put on some pretty fast moving light shows during picking.
Unread 10-03-2014, 18:46
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
To my knowledge, this happened once in eliminations at Mt. Olive. Since only one ball was interfered with, we gave the bonus.
I also recall seeing video of it happening at Centerline.
Unread 10-03-2014, 18:53
Jared's Avatar
Rookie Year: 2012
Here's a video. We shoot the ball in the far goal at 6 seconds into the match.
http://www.youtube.com/watch?v=95lCy...RUwWvGvG8PnQpA
Unread 10-03-2014, 18:55
Unsung FIRST Hero
Karthik Karthik is offline
VEX Robotics GDC Chairman
Rookie Year: 1998
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
We definitely noticed it being an issue at GTRE, and had to add in one second delay to make sure both our shots were fired on the correct goal.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 10-03-2014, 18:59
Yipyapper's Avatar
St. Louis Or Bust
AKA: Aaron Gordon
Well, we had issues with the drive train early on and couldn't actually get going for the auton during that time, so I'm guessing that we just had the good fortune of having the camera delay how it sensed the hot goal once we got going.
I mean, that'd be a problem anywhere else and I definitely will be looking into that, but this time a delay in input seemed to work to our advantage
Unread 10-03-2014, 19:03
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Everything in the FMS is connected by ethernet. With all the ref's talking about lag in the tablets, the issues with the hot goals, and the timing of the sounds, all of which I've noticed, I think they are all related to lag somewhere. The FMS normally doesn't seem as off as it has this year, but thats where I think the issue is, and I hope they get it fixed soon, because its causing problems.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 10-03-2014, 19:05
AKA: Scooby
I noticed the timing of sounds but didn't see a connection. This happened with the end buzzer at MO very often and Groton at least once; a delay between the match ending and the robots stopping(usually stopping first). One match in Elims at Groton even had the "ding ding" not play, but I don't know if that was the FMS though.
Unread 10-03-2014, 23:23
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
I noticed a significant hot goal delay at the start of autonomous at both GTRW and GTRE.
I also felt that matches were ending about 1 second before the match timer expired and the buzzer sounded.
In life, what you give, you keep. What you fail to give, you lose forever...
  #15   Spotlight this post!
Unread 11-03-2014, 00:02
Originally Posted by Mr. Lim View Post
I noticed a significant hot goal delay at the start of autonomous at both GTRW and GTRW.
We also noticed robots being disabled 1-2 seconds before the lights going out.
