Conveyor Belt treads idler & Sprocket help
Hello everyone!
This is my first post here, not entirely sure I am post this in the correct location. I am want to get some suggestions on how to drive a conveyor belt I purchased for a large scale robot I intend to build. The conveyor belt I purchased is from McMaster Carr (Link here). The belt has a smooth, cloth backing which is where I'm at a loss. I've seen most of them that have ridges or something to grab onto so it can be driven but in this case I can't. Is there a way to modify this belt? Or, do I need to cut my losses and purchase another belt from McMaster? ![]() |
Re: Conveyor Belt treads idler & Sprocket help
Never made a conveyor belt before.
But I would probably just tension the belt nice and tight, and friction drive it. That is, get some sort of rubber rollers for it to ride on, and just drive one of them. |
We did something similar for our frisbee shooter last year. Totally depends on the appilcation
Put a roller on the other end and tension appropriately (you may need to add guides to the ends of each roller if it tracks off of the rollers). In the middle add bogeys (rollers with some spring force to keep the conveyor from getting pushed in) or a press plate (to back the conveyor, again to keep the conveyor from getting pushed in). BTW: Welcome to CD |
Buy some rollers that are made for the job.
Steel rollers are usually used for this application, although nylon rollers will work also for lower tensions. A slightly convex roller is usually used on one end, so that the belt stays centered automatically. |
Watching a crowned pulley high center and automatically adjust a belt as side loads are applied for the first time is like spooky voodoo magic happening right before you. You just want to see it roll off the side but nope it just chills out in the middle. Last edited by RoboChair : 20-03-2014 at 03:49. |
