Re: HTMLish based scouting
Here is a test google form i put together https://docs.google.com/forms/d/1fCb...DVMhM/viewform if people can fill out the form with test data that would be great. Because it is just test data if you could keep the "match number" field to any number under 20 and for "team number" keep it any number under 1000 all other fields just keep realistic(no ones going to be scoring 9999999 points in a match). If you have any suggestions/criticisms/things i should add please put them in the "notes" section
How should I be judging the coordinates fields, and "Points Made"? I've seen teams score way more than 10 points, and there is not enough information to make a good judgement on coordinates (relative to where, what unit to use).
the scouts up in the stands will have a gridded off picture of the playing field. i would want to know where on the field the robot shot from the most. I will probably get rid of the "points made" field. originally it was going to say how many total points the team made excluding assists. I may change it to ask what their total contribution to the alliance was as far as points(1 high goal, 1 assist, and 1 truss shot would be 10+10+5=25)
Actually, 1 assist is worth 0 pts/robot. 2 is worth 5 pts/robot, and 3 is worth 10 pts/robot. You'll want to consider this. |
Fixed. I took that field out
heres the new link: https://docs.google.com/forms/d/1fCb...DVMhM/viewform not sure if the old one still works
