Go to Post Solutions are more likely to be implemented if you provide the solution along with the concern! - Jessica Boucher [more]
Unread 13-03-2014, 21:45
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Rookie Year: 2014
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
SendableChooser Not Showing Up On SmartDashboard
We have been using the SendableChooser class to create an autonomous selector on the SmartDashboard. I need to clarify that the selector does work and show up (most of the time). When the selector is working it allows us to switch between autonomouses perfectly.
The problem is that every once in awhile the selector doesn't show up on the SmartDashboard. I have verified that when this occurs the selector is in the NetworkTables by using the Table viewer. To try to fix it I have rebooted the drive station, power cycled the robot, and reopen all programs on the driver station.
The only solution that I have found is to reformat the cRIO. This solution works just fine, but it does take several minutes to reformat and push code. I would like to know if anyone has any other solution so that we don't have to forfeit a match for not having working cRIO.
Unread 14-03-2014, 15:40
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: SendableChooser Not Showing Up On SmartDashboard
Are you saying when the sendable chooser does not show up, the only way to get it to show up is to reformat the cRIO?
Restarting the robot, then turning on the driverstation, and opening smartdashboard in that order does not fix the problem?
Where in your code do you instantiate the sendablechooser, and where do you read its value? i.e. I am looking for a response like "we instantiate it in RobotInit() and read it in AutoInit()"
Pasting the key parts of your code would be helpful.
Regards,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
